Framing Nailer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2007, 06:20 PM   #1
Framing Nailer
I am considering purchasing a framing nailer. I'm not clear on the various angles. What should I be looking for in a good all around gun? Also what about nail size and round vs. clip head nails?
joe3534 is offline   Reply With Quote
Old 05-15-2007, 07:07 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Angles are slightly different by manufacturer. I wouldn't worry about what angle the gun nails are loaded at....
What is a good all around gun is depenant on how much money you plan on spending....
That is more of an issue as to what is permitted in your area. Clipped head nails are not permited, by code, in my neck of the woods....
- Build Well -
Old 05-15-2007, 10:33 PM   #3
remodeling pro
First, do as AtlanticWB suggested and see what code requires in your area. The requirement for full head nails, which used to be primarily for areas with siesmic activity is rapidly spreading to the coastal areas to meet upgraded codes for hurricane strength. Personally, if you stick with the provens like Paslode or Senco, you will get many years of service, and good performance. I don't feel that the newer Bostich products are up to the same toughness as the older models, and if you only require moderate use, the Porter Cables or Ridgid products will be less expensive. Also be sure that the nails for your chosen brand are widely available in your area, as some brands have more of a following in different regions than others.
troubleseeker is offline   Reply With Quote
Old 05-16-2007, 02:14 AM   #4
That is more of an issue as to what is permitted in your area. Clipped head nails are not permitted, by code, in my neck of the woods....
Really no clipped heads. What is the reasoning behind that. I have used both and you can't pull either one out the wrong way (at least not without a lot of damage). It is really interesting to here the differences in codes in different areas. It makes one wonder why they are not more uniform. Sure some areas that have earth quakes need something different or hurricanes but still it amazes me. If one way is best why do we not all just build the best that can be built then we would all be safe.
warnerww is offline   Reply With Quote
Old 05-16-2007, 10:25 AM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Yea, I have done re-hab work in hurricane areas where clip head nails are not allowed. They are allowed in my home area. I just got the round head nailer so I would have more flexibility.
Only advantage to a clipped head nailer, I think, is you get a couple of more nails per stick.
Brik is offline   Reply With Quote
Old 05-16-2007, 12:00 PM   #6
The thing I don't like about the full rounds is those little pieces of plastic that get stuck it the wood. It is no big deal most of the time but sometimes I have to dig them out if I am face nailing siding or something. I own both guns but had no idea half rounds are not allowed in some areas. Good too know thanks again guys.
Old 05-16-2007, 12:50 PM   #7
Paslodes, and I believe Hitachi as well, use paper connected nails, not plastic. There may be a few others that use paper collated nails.
- Build Well -
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
What kind of Nailer? Oldhouseowner Tools 15 02-15-2009 07:36 PM
Need Help With Framing Nailer Stingray Remodeling 5 03-18-2007 09:50 AM
Framing Nailer (Porter Cable) Renovator Tools 2 04-26-2006 07:43 PM
2hp / 6gal Compressor w/ framing nailer scarrell Tools 4 04-24-2006 09:34 AM
