Framing Nail Gun Is Blowing Holes In My Fence - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 11:01 AM   #1
Framing nail gun is blowing holes in my fence
I rented a Framing nail gun to make hanging my fence boards easier. Now my problem is that the nail gun seems too powerful, Its making large holes in my fence around the nail heads. I've brought the psi down to 25, and it helps a little, but there is still a little damage around the nail. But when the psi is low the next nail takes two trigger pulls to come out. Which in turn adds more damage.
Any suggestions?
Oh, am I supposed to take the tape off the nails before loading the gun?
Thanks!
TheMac13 is offline   Reply With Quote
Old 06-28-2010, 12:10 PM   #2
jlhaslip's Avatar
Rewards Points: 2,204
the air pressure needs to go up to around 90 PSI for the gun to work properly.
some guns have a depth adjustment on the tip to set the nail head properly.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 06-28-2010, 03:55 PM   #3
When the pressure is that high the nail sets too deeply and the gun I rented has no adjustments. I'm going back to good old elbow grease.
Thanks for the reply.
Old 06-28-2010, 05:24 PM   #4
Rewards Points: 5,336
The compressor will have a pressure setting that is adjustable. Adjust it.
If you can't fnd the adjustment, post the make and model number of the unit and we'll help you find it.
Ron
Old 06-28-2010, 05:31 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
framing gun is not the best for finish work,you may be able to get a rubber no mar tip for it which should help,i would use a coil siding gun such as a makita an611
Tom Struble is offline   Reply With Quote
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
Frustrated/Confused in FL Fence jjrbus Building & Construction 5 09-02-2009 09:52 AM
clipped FINISH vs. FRAMING nail amakarevic Building & Construction 4 04-25-2008 03:46 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 11:37 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
