Old 10-11-2012, 10:15 AM   #1
framing with metal studs
I have been googling framing with metal studs and I think it is what I want to do. I am planning on building a 7ft wall to make my master bedrooms closet bigger.
The whole process seems very simply, but I am looking for some guidance on how to frame a door using metal studs. Are there any walk through tutorials
BigRedFan is offline   Reply With Quote
Old 10-11-2012, 10:42 AM   #2
Why metal studs?
A 2 X 4 wall would only need a hammer and a saw, not that hard to do.
Old 10-11-2012, 10:52 AM   #3
Originally Posted by joecaption View Post
How metal studs?
No real reason. I guess using wood is a possibility. I just liked how the metal studs fit into the track so easily
Old 10-11-2012, 11:02 AM   #4
DIY Enthusiast
sublime2's Avatar
How metal studs?
And not much time to construct.
Metal studs will require special screws to attach metal studs to eachother and the rock you going to attach to it.
If the project were bigger,maybe use metal.
For this project I think your better off with wood.
sublime2 is online now   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
BigRedFan (10-11-2012)
Old 10-11-2012, 11:07 AM   #5
Ok any resources you could provide on how big to make the space for the prehung door.
Old 10-11-2012, 11:15 AM   #6
DIY Enthusiast
sublime2's Avatar
Pre hung door common size for a closet is 28" x 78" I think.of course you can use bigger o.es if you chose.
You want to make the rough opening 2" wider & 2" higher then the door with frame.
So for the above door the rough opening would be 30" x80".
http://www.sawkerfs.com/Rough_Openings_For_Doors.html
Old 10-11-2012, 11:31 AM   #7
Thank you so Much!!
Old 10-11-2012, 03:46 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
for a roiugh opening for a door in steel stud you simply screw a 2x4 to the steel stud to create the nailer for hanging the door plus it stiffens up the opening
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (10-11-2012)
Old 10-11-2012, 03:47 PM   #9
I did the math and it was an about 40 dollars for all the wood i would need. Seems like the best way to go
Old 10-11-2012, 11:22 PM   #10
What type of door bifold or swinging?
If bifold - What type of jambs, drywall return? 1/2 jambs? full jambs?
Makes a difference on size of opening
mae-ling is offline   Reply With Quote
Old 10-12-2012, 10:11 AM   #11
going to do a 28" swinging door
Old 10-12-2012, 07:53 PM   #12
you can do a 30" opening if the jamb stock is 5/8" and both sides of the opening are perfectly plumb.. nothing i hate more than trying to hang doors in rough openings that are tight and not even plumb
mae-ling (10-12-2012)
Kitchen cabinets to metal studs antlerdancer Kitchen & Bath Remodeling 4 02-21-2012 04:03 PM
metal studs on drywall patg Drywall & Plaster 4 12-29-2011 02:56 AM
heavy shelves, metal studs... themikeindy Carpentry 2 03-28-2011 10:36 AM
metal framing 614sbroadway Building & Construction 0 06-01-2010 10:47 AM
Metal Plate for Stud's Face to Protect Cable Lovegasoline Electrical 17 12-04-2009 07:40 PM
