Framing Joists To Concrete Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 04:50 PM   #1
Framing Joists to Concrete Ceiling
Hi Guys
I have a concrete bunker room under my garage. The walls and Ceilings are both concrete. When I purchased the house the walls were already framed with metal studs. I was wondering what my options are for framing or making joists on the ceiling to attach drywall too. And also I would like to put lighting into the ceiling in forms of small pot lights. This is going to be my theatre room. The room measures 22x22 feet.
Any help would be appreciated.
polonez is offline   Reply With Quote
Old 03-19-2011, 06:45 PM   #2
Rewards Points: 1,668
What is the ceiling height; looks a bit like 100"?
bob22 is offline   Reply With Quote
Old 03-19-2011, 07:05 PM   #3
good eye! 100" it is
for the floor im going to be using delta fl stuff with laminate so the floor will not be raised that much
Old 03-19-2011, 08:56 PM   #4
liscenced electrician
Rewards Points: 538
how in the world did you notice that from 96"?
jimmy21 is offline   Reply With Quote
Old 03-20-2011, 12:36 AM   #5
Registered User
Rewards Points: 526
The 4' insulation batts, which shouldn't really be there.....
Gary
Old 03-22-2011, 11:18 PM   #6
No one has any suggestions or ideas???
Gary..Maybe you can tell me why they shouldnt be there? Like I said I just bought the house and that is how it came. The home inspector said it was fine because they studs are 3 inches away from the concrete.????
Maybe you can help me out and tell me what should be there instead
Old 03-23-2011, 01:28 AM   #7
Rewards Points: 1,016
This is under your garage? Vehicle parking on top? I am interested to know the construction of the concrete ceiling to stay up there?
Instead of drywall, how about a close clearance suspended ceiling? Anchors into the concrete to hang it from?
Old 03-23-2011, 06:32 AM   #8
I guess you could attach 2x4s flate on the ceiling to the ceiling with a ramset, then 2x4s on edge on the side of the attached 2/x4s (forming a L shape). Then 90 degrees to these, nail 1 x 3s, then sheetrock it. This should give you if math is right, the 4" drop to the top of the wall framing. Or, suspended ceiling as suggested, may be a lot easier.
Old 03-23-2011, 01:54 PM   #9
Tizzer's Avatar
Rewards Points: 460
I can only think of the suspended ceiling tiles.
Tizzer is offline   Reply With Quote
Old 03-23-2011, 02:47 PM   #10
Thanks for the suggestions guys
I think im going to go with the suspended ceiling.... much less work than trying to hang 2x4s up...i did think of that too.. just seems like alot of work and alot of weight hanging over if anything ever happened (earthquake) or what not.
For a suspended ceiling ... Do you guys think I should glue up some hard styrofoam insulation? or leave it as is since I have the garage above...
Im just a little concerned about the Cement mildue type smell in the room ???
Thanks again
Pat
Putting up a drywall ceiling...will need to drill into concrete. netvivi Remodeling 7 02-14-2010 06:13 PM
Annie5 - framing over uneven concrete floor Annie5 Carpentry 9 11-22-2009 03:26 PM
Removing ceiling joists jbarre Building & Construction 5 09-11-2009 10:27 PM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 10:44 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
