Framing Issue W/load Bearing Wall And Load Center Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 10:31 AM   #1
Framing issue w/load bearing wall and load center replacement
I'm gearing up to replace the load center in our 1965 house, and am contemplating methods for installing the new panel, and framing has become a bit of an issue.
Currently, the load center is surface-mounted in what used to be the garage, which was converted to living space some time in the mid 70's. The PO constructed some haphazard closet during the conversion that hid the panel, but violated every bit of code regarding load center access, and several laws of common sense. Anyway, the "closet" has been demolished now in preparation for replacing the load center. Now that I can finally see what I'm dealing with, it's time to plan this out.
Obviously, this is a load bearing wall. It's also between a corner and the windows which occupy the space that formerly held garage doors. The real problem is that the available stud space is about 1-1/4" shy of being able to hold the typical 14-1/2" wide flush mount panel. I could simply build out the wall with studs to hold the new box, but cosmetically, that leaves a lot to be desired.
I've already burned up half of my brain cells trying to find out if any such thing as a narrower 200A load center was available, with zero results.
I can't relocate the service entrance without needing to replace vinyl siding that has not been available since the early 90's, nevermind the amount of money that the utility company would extract from my emaciated wallet for the new overhead drop.
Before I resign myself to building an ugly bump-out on the wall to enable me to flush mount the new panel, I thought I would see if anyone had any other great thoughts. I don't really want to bring in an engineer, but if there is some possibility of creating the required stud space without needing the tear down siding and deal with the subsequent three ring circus that would follow, then I would be open to writing a check for someone with the smarts to give me the solution on paper. Before I get to that point, I thought I would see if anyone here could provide some inspiration.
Framing issue w/load bearing wall and load center replacement-2013-09-10-05.54.45.jpg   Framing issue w/load bearing wall and load center replacement-2013-09-10-05.53.17.jpg
KAdams4458 is offline   Reply With Quote
Old 09-10-2013, 11:31 AM   #2
Rewards Points: 626
Well first off you need a WA L&I Electrical permit, and you will have to get a building permit too because of the need for the electrical permit. Your solution is simple you can move one stud over to were you need to be so you can place the load center. a load bearing wall can be 24" OC even with 2x4"s so just knock one out move it over to were you need it to be and voila problem solved. Just get that L&I Permit.
Nailbags is offline   Reply With Quote
Old 09-10-2013, 01:25 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
Is that a sub-panel?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-10-2013, 03:30 PM   #4
I've had the electrical permit for two weeks already, but moving a stud over isn't possible. The two on the right of the cavity are the jack and king studs for the header over the window, and the three on the left are... I don't even know what you call it. I have no idea of one of those can be removed safely, or altered with some other sort of support like a fabricated steel plate. This is why I am looking for inspiration that may lead me to consulting an engineer.
The third stud on the left side of the cavity isn't clearly visible in the pictures. It's behind the wall on the left, and only two are visible, but the third one is there, I promise. It's basically a 3-stud corner, but it's not really a corner, it's just where the garage wall and lower elevation foundation meet the house wall and its higher elevation foundation. To make it really interesting, the short wall you see jutting out from the left side in the pictures is also a load bearing wall.
I have no idea why they build some things the way they do, but I'm guessing they had a reason. Ha!
Old 09-10-2013, 03:32 PM   #5
Nope. That's the only distribution point in the house. It's back to back with the meter base outside.
Old 09-10-2013, 06:01 PM   #6
"You can do anything"-Mom
brockmiera's Avatar
It looks to me that you could do without that extra stud in the corner. Its usually that way to have space to nail drywall from both directions but you'll have that even if you remove the extra stud there.
brockmiera is offline   Reply With Quote
Old 09-10-2013, 07:21 PM   #7
This is conceivable. I looked above, and there are no top plate joints over this short section of wall. Exactly one of the rafter and ceiling joists lands on it, and the rest all land above the header over the windows, so just deleting a stud seems like it would work.
Question regarding new load center on cinder block wall. chris_b Electrical 11 02-28-2013 04:56 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
