Framing Interior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2006, 07:26 PM   #1
Framing interior walls
The outside walls of my basement storage room was done proior to my purchase of the house, I would now like to finish off the space. When framing it do I frame to the existing wall ( the drywall) or remove that section and frame to the studs of the existing wall?
TIA
Robb
Parker is offline   Reply With Quote
Old 05-13-2006, 11:47 AM   #2
Darylh's Avatar
If there is a stud behind the drywall where you new wall is going then just frame away, but if there is no stud you will have to remove a section of drywall from the center of each stud closest to where your wall is going and either make a wall pocket( 3 studs which make up 6- 1/2") or blocking 2 foot on center.
Darylh is offline   Reply With Quote
How do I find a framing contractor in Rhode Island christy123 Building & Construction 2 10-25-2006 11:29 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
2hp / 6gal Compressor w/ framing nailer scarrell Tools 4 04-24-2006 09:34 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
