Is Framing An Interior Wall With 2x3s Up To Code - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 12:18 PM   #16
MarginallyQualified
Rewards Points: 2,464
Originally Posted by dmack7 View Post
I'm having difficulty selling my 2 bedroom townhouse...
so I think my next step is to add a bedroom.
Shoehorning another bedroom in won't fix your PRICE problem.
Old 07-31-2013, 10:36 PM   #17
Registered User
Rewards Points: 5,482
I'm having difficulty selling my 2 bedroom townhouse so I think my next step is to add a bedroom. The resulting rooms are going to be small as it is so my question is can I divide the current room into two separate rooms by framing a wall that is made from 2x3s?
Yes on that, code acceptable; (depending on location) see chart R602.3 (5); http://publicecodes.cyberregs.com/ic...9_6_sec002.htm
Gary
Old 08-01-2013, 05:58 AM   #18
Rewards Points: 4,796
Gary
It's interesting that is to code, since it throws off things like pipe and electrical cable spacing. It doesn't seem like you could put a cable through those studs to code. A standard drywall screw could pierce it. I wonder if that's handled elsewhere in the codes.
jeffnc is offline   Reply With Quote
Old 08-01-2013, 10:28 AM   #19
Rewards Points: 150
What's thrown off? You just put your 1/2" hole 1-1/4" from one side, then it is 3/4" from the other side and you cover that w a nail plate. There probly isn't anything more significant than a 12/2 going thru this wall since it's an addition.
And if no elec at all then even better. For example where you have opposite facing side-by-side closets then the little wall between them need not be anything significant at all. You could even do this w 2x4's sideways. You gain an inch in each closet of otherwise wasted space.
Most builders would look at such ideas and go that's a waste of time... but they're not the owners so they don't care about those two inches. Look at the technologies employed in mobile homes... there are less conventional ways to do things and inches matter if you have a small space.
SquishyBall is offline   Reply With Quote
Old 08-05-2013, 12:05 PM   #20
Registered User
http://publicecodes.cyberregs.com/ic...9_6_par019.htm
Gary
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Rafter framing code question anesthes Building & Construction 32 01-21-2011 10:43 PM
error code 45 Turtle learner HVAC 2 01-10-2011 04:09 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
