Is Framing An Interior Wall With 2x3s Up To Code - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 09:47 PM   #1
Rewards Points: 28
is framing an interior wall with 2x3s up to code
I'm having difficulty selling my 2 bedroom townhouse so I think my next step is to add a bedroom. The resulting rooms are going to be small as it is so my question is can I divide the current room into two separate rooms by framing a wall that is made from 2x3s?
dmack7 is offline   Reply With Quote
Old 07-20-2013, 09:51 PM   #2
Old School
Willie T's Avatar
A 2x4 is 3 1/2" wide. That's a half inch more than 3"....... divided by both rooms, you save yourself a whopping 1/4" per room.
C'mon now, the head is supposed to be used for more than just a hat rack.
And, yes, if you buy 2x3's that are really 2 1/2" wide, you can gain another 1/4" in each room. Is any of this worth the trouble to make flimsy walls to save, at the most, the width of your little finger in each room?
Don't forget the hassle you'll encounter getting door jambs to fit... and are you sure the electrical boxes are going to fit.....? Probably will, but then again....
BTW, in small rooms, pocket doors are a big help. You can't find 2 1/2" pocket door frames.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
gregzoll (07-31-2013)
Old 07-20-2013, 10:57 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
not to mention that 2x3's are more susceptible to twisting and warping as they dry out.. which makes for a incridibley wavey wall
not to mention that theres a much higher chance of a finish nail hitting wires or pipes that might be put in the wall.. code states that wires and pipes must be kept back a minimum 1 1/2" from the inside edge of drywall in the wall cavity
woodworkbykirk is offline   Reply With Quote
Old 07-21-2013, 07:23 AM   #4
Rewards Points: 502
Would the house sell better if, instead of making one room into two small rooms, you just added a small bathroom to the room.
tony.g is offline   Reply With Quote
Old 07-21-2013, 08:44 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
I have actually seen walls in prefab structures that were nothing more than 3/4 inch osb with vinyl wall covering. I would guess that no one in their right mind would find it a desirable thing. Also, if you can't sit down on your bed without cracking your head on the wall then what you have is a big closet rather than a bedroom. Our 1933 bungalow 2 bedroom home had a big addition put on back that serves as our bedroom. The 2 original bedrooms were too small so they are now a closet and a man cave.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-21-2013, 08:54 AM   #6
Rewards Points: 13,232
Two tiny rooms instead of one big bedroom would be a complete turn off to me if I was a buyer.
I assume your using an agent to try and sell this house, have you talked to them about why the house is not selling?
Could be dozens of reasons, bad area, bad schools, roof needs replacing, peeling paint, poopy looking yard ECT.
I once worked on a house that was for sale for $275,000 for three years and never even had a showing. I drive up and there's an engine hanging from a tree, no grass in the front yard, they had a working hot tub but had decided to fill it with sand to make a kids play area, railing broken off the deck, stairs to the deck laying on the ground, all the screens were broken, hole in the sheetrock, door jambs split in half from the couple fighting and locking each other out.
The owner kicked the tenets out (her grandson) we spent three weeks fixing it up and the house sold in 4 days.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
gregzoll (07-31-2013), oh'mike (07-21-2013)
Old 07-21-2013, 09:08 AM   #7
Rewards Points: 3,130
Turning one bedroom into two might well make them so small that they wouldn't legally qualify as bedrooms. Each would also require a closet. And then there's the possible issue of egress. Altogether, your plan is a bad idea.
There's something else that's making it hard for you to sell. About ten years ago, we owned a 3-story, 2-bedroom townhouse. When we decided to move, it sold in less than a week.
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
gregzoll (07-31-2013), RWolff (07-31-2013)
Old 07-21-2013, 04:29 PM   #8
Rewards Points: 502
What was that all about? Must have been one hell of a crash!
Old 07-21-2013, 05:31 PM   #9
More likely a shade tree mechanic.
Old 07-29-2013, 11:35 PM   #10
Rewards Points: 1,442
The next owner can film cool fight scenes where they throw each other through the wall.
I believe a room must have a closet and a window to be considered a bedroom.
mikegp is offline   Reply With Quote
Old 07-30-2013, 12:03 AM   #11
GBrackins's Avatar
Rewards Points: 2,108
the only requirements I know of in the 2009 International Residential Code for a bedroom are:
1. at least 70 s.f. of area
2. no dimension less than 7'
3. an emergency escape and rescue opening in an exterior wall
4. a door
5. space intended as an area for sleeping.
some local jurisdictions use the "closet" as a deciding factor, but nothing in regards to closets is called for in the IRC.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
AndyGump (07-30-2013)
Old 07-30-2013, 08:25 PM   #12
Old School
Willie T's Avatar
Many European homes have no closets. They often have schranks (I think that's German for cupboard cabinet, something like a "wardrobe") Anyway, freestanding cabinets.
Willie T
Old 07-31-2013, 12:43 AM   #13
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I'm not convinced carving out one small already room into two smaller still rooms is going to suddenly sell the house, and depending on potential buyers it might have the opposite effect if they expect LARGE rooms and they see these two tiny rooms.
The economy sucks, it is NOT a seller's market there's a glut of houses for sale, as well as a glut of abandoned, and foreclosed-on houses with for sale signs no one wants.
If someone likes the house they would have no problem putting in a partition wall IF they really wanted 3 bedrooms instead of 2, I think you would be throwign away money on doing this.
RWolff is offline   Reply With Quote
Old 07-31-2013, 12:39 PM   #14
Rewards Points: 150
So many replies w editorials about a simple question. Sure you can use 2x3's for a non load bearing partition wall. I wouldn't tho if there is a door in that wall cuz you'll pay more than you saved getting a custom door jamb. If there will be no door and only a couple outlets then you're fine!
How small is "small"? Everyone is criticizing and they don't know the starting dimensions. I find a 10x8 bedroom to be perfectly fine for a kids room. If my choices are:
2-bedroom with
Master 14x18 (252 sf)
2nd bedroom 12x16 (192 sf)
Or
3-bedroom with
2nd bedroom 9x10 (90 sf)
3rd bedroom 9x10 (90 sf)
The 3-bedroom is actually 12 sf smaller but I'd take it any day. Far more useful to have the extra room even if small. As long as it isn't hokey... i.e. it flows normal in the house, has a nice closet, window, etc. Sometimes things get split up and they are terrible changes in terms of design.
I don't know many families who are in the market for a 3-bedroom house that would go "oh a 2-bedroom is okay if they're bigger rooms". Generally your market for 2-bedroomers are a completely separate market from your 3-bedroomers, so yes, changing the config might get you to see some fresh buyers if the 2-bedroom buyers have seen it and passed already.
Give some thought along the lines of if all the 2-bedroom buyers saw this and passed, why will it be different once you're talking to 3-bedroom buyers... i.e. is your price right?
SquishyBall is offline   Reply With Quote
Old 07-31-2013, 12:46 PM   #15
Rewards Points: 6,652
We should start using Shumaker Scott's German House Rebuild in how to make a small building work as a home.
The Following User Says Thank You to gregzoll For This Useful Post:
concretemasonry (07-31-2013)
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 08:24 AM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 11:13 PM
Rafter framing code question anesthes Building & Construction 32 01-21-2011 11:43 PM
error code 45 Turtle learner HVAC 2 01-10-2011 05:09 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
