Framing An Interior Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 05:39 PM   #1
Framing an Interior Door
We're still in the process of having a home built and I've got a question regarding the framing of a door.
The builder incorrectly framed a double-door opening such that it was too high. The problem wasn't discovered by the builder until after the drywall was already put into place. Rather than tear out the drywall and re-frame the opening, the builder decided to drop the opening by installing a piece of wood across the door in the manner shown in the attached jpg file (see framing colored in blue) and then putting a piece of drywall over the extended opening.
Question: Is this an acceptable method to correct the size of the frame? And secondly, should I expect to see any problems surface later (such as drywall cracks developing in the patched up area)?
Note that I'm showing a picture for a single door, but the opening in question is actually for a double door.
Thanks in advance for any advice.
Regards,
Jim
haganjp is offline   Reply With Quote
Old 11-20-2012, 06:26 PM   #2
Rewards Points: 512
if the drywall mudding is done correctly then i dont see any issues.
princelake is offline   Reply With Quote
Old 11-20-2012, 07:00 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
prince is right. as long as the framing doesnt move its fine. this is done all the time in remodel situations where existing openings are changed. provided its not structural.. if its structural local codes must be followed
woodworkbykirk is offline   Reply With Quote
Old 11-20-2012, 08:13 PM   #4
Rewards Points: 454
Even if its a load bearing wall there will allready be a header all he is doing is making the opening smaller.So there will be no problem with what he is doing.
scottktmrider is offline   Reply With Quote
The Following User Says Thank You to scottktmrider For This Useful Post:
mae-ling (11-20-2012)
Old 11-20-2012, 08:37 PM   #5
Thanks everyone. I'm glad to hear that it shouldn't present any problems.
Regards,
Jim
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 12:01 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 09:12 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
