Old 04-26-2009, 07:14 PM   #1
lanktree2005
Framing and installing 5' x 6' window
Hi,
I'm building a bedroom addition to an old cabin.
Got a deal on a nice 5' x 6' high window with 5 panes: 2 inward opening ones on either side of a large top to bottom one and 2 smaller ones above the opening ones.
It will go in an 8' wall.
It has no frame.
1. How high should I put the window?
2. Any special framing considerations?
lanktree2005 is offline   Reply With Quote
Old 04-26-2009, 10:21 PM   #2
Two means of egress is required for a bedroom. (Emergency escape) One is the door to the house, other exterior door or window.
The window has to be: 1. 44" maximum above finished floor;
2. 5.7square feet minimum clear opening;
3. Minimum 20" width & minimum 24" height (clear opening);
4. No windows closer than 3' to power line;
5. Req'd glazed openings must open to street, yard or court on same lot. Be safe, G
GBR in WA is offline   Reply With Quote
More On This Topic
So here we are, on the other side of the room, and it's just getting so exciting. We hope to wrap this up, in the next couple of days. Tomorrow our closet gets installed, we have, my idea, about the door, still to execute with cutting it in half... Read More »
Trick or treat, I'm Mat Cail on behalf of Expert Village. I'm here today to show you how to prepare for trick or treaters. Alright first thing is first, before any trick or treaters can get to your door you have to make sure you have a nice clear lit... Read More »
In the event of a fire in the house, you make sure that you stay low underneath the heat and underneath the smoke. You come up to the door; check the door with the back of your hand. If the door’s cold, then you can open up the door and go through... Read More »
Hello everybody. My name is Tanner Falcon from Danny Tanner's Window Washing on behalf of expertvillage.com and right now I want to talk about what I call mud but it's actually water spot remover. This is key because a lot of your windows are going to be... Read More »
Trick or treat, I'm Matt Cail on behalf of Expert Village I'm here today to show you how to prepare for treat or treaters. Now that we dealt with the exterior we're going to move inside the house to prepare for trick or treaters. Now you might be asking... Read More »
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
Cut and install new window mustanger Building & Construction 4 12-01-2007 12:18 PM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 07:33 PM
Need Help With Framing Nailer Stingray Remodeling 5 03-18-2007 09:50 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
