-   -   Framing help needed (http://www.diychatroom.com/f19/framing-help-needed-128108/)
joeh 12-29-2011 06:02 PM
Framing help needed
I am currently involved in a kitchen reno. I have a wall that's over 3/4" out of level from bottom to top leaning outwards. This will be a U shaped kitchen, and there will be angled 24" cabinets on each side wall onto this window wall. On the right hand side there are 4 studs running up, each attached to each other. On the left hand side, there are 2 studs, then a vent where I wouldn't be able to sister in a stud, then 3 studs. The window is being replaced in a few weeks, so whatever I do to the wall won't incorporate that.
Here's an image of the wall:
http://i761.photobucket.com/albums/x...mingCustom.jpg
I've used the red to mark out all of the studs, and there are a bunch of them on this wall. I had a few ideas, but nothing seems "easy":
  • Rip boards and shim out from top to bottom? This just seems tough with the number of boards to rip.
  • Sister to the inside boards and shim out the solid regions? This leaves minimal room for insulation, and there's a cross brace running the length that means I have 2 areas to level for each. Plus lots of ripping.
  • Pull out the inside boards, re-frame, and shim solid regions? Each board, even cross, are attached to the sheathing, which means big damage. And more ripping.
  • Leave as is as there will be base cabinets where the counter will mask it and just two upper corner cabinets?
  • Something else I haven't thought of?
I really don't know what should be my next step, so some ideas or confirmation of mine would be great... Thanks in advance...
TarheelTerp 12-29-2011 06:08 PM
Originally Posted by joeh (Post 806713)
I have a (LOAD BEARING EXTERIOR) wall that's over 3/4" out of level
from bottom to top (over about six feet) and leaning outward.
I really don't know what should be my next step...
Look into WHY and HOW this condition exists...
and before doing ANY other modifications... FIX THAT.
hth
Ninjaframer 12-29-2011 06:11 PM
When I framed in las Vegas we shim & shaved every house, especially kitchens where cabinets would be installed. If it was me I would rip 2x material and fur out till I was close and then use paper shims to get it perfect. Maybe you aren't familiar with those- the make cardboard shims about 4' long and 3/16 thick. They come in bundles and are made for shimming studs so they fall in plane with each other.
joeh 12-29-2011 08:31 PM
hth
55 year old house, structural engineer fairly certain all movement has stopped (had some cracks that made no change over 5 years now).
Never heard of the cardboard shims, I'll check it out next time I go to Home Depot or whatever. Thanks for the thoughts.
havalife 12-29-2011 10:33 PM
It looks like the best way is to cut and furr the out of plumb studs. It may seem like a lot of work but if you cover it up then you will have to live with the end result. Always fix the issue before you cover anything.
