Framing A Half Wall For A Bar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2008, 08:37 AM   #1
Framing a half wall for a bar
We framed a half wall this weekend for our bar. It is shaped like half of a hexagon. Only one end is anchored to a wall. We are concerned that is is so wobbly. The studs are anchored tightly into the concrete but the top of the wall jiggles quite a bit when we shake it. Is this normal? We don't want to drywall and add granite CT and then have it topple under the weight. Any ideas on how we can secure it better?
QueenL is offline   Reply With Quote
Old 04-01-2008, 10:02 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
It should be stable. if it racks a little across the face that will stop when drywall is applied, if it can move forward back then it should be secured better.
Screws can help a lot. Construction adhesive can help too. If both have been used then a piece of steel angle iron may be required. This can be 'let in' to the inside of the wall and also set into the concrete so it will not show through the finish materials (floor and wall).
Brik is offline   Reply With Quote
Old 04-01-2008, 11:59 AM   #3
Custom Cabinet Maker
Did you only go with a single top plate? also you might want to screw and glue plywood to both faces then sheetrock. you can also do solid blocking within the bays, diagonal bracing etc. How did you anchor to the concrete?
skymaster is offline   Reply With Quote
Old 04-01-2008, 12:37 PM   #4
Could you provide a picture? It sounds wobbly because it's narrow, but that's just how it's sounding in my head. Maybe it just needs to be beefed up a bit? It should be fairly rock solid. Sheetrock should help a bit, but will only prevent movement in 1 plane. If it's moving the other way, it won't help.
perpetual98 is offline   Reply With Quote
Old 04-01-2008, 01:01 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
One option (that is after the fact), is to install the open end of the wall as you would a railing newell post. In other words; open the floor to gain access to a floor joist. Instead of using a 2x4 on the end, use a 4x4 fir post. Notch it and install with lag screws to a floor joist, or build out the side of the closest floor joist to solidly lag screw the "wall post" into. This process of installation reduces vertical movement to almost zero.
- Build Well -
Old 04-01-2008, 01:18 PM   #6
We did do a single top plate. Does that add much to the stability? We thought that the only significance of doubling was for drywall. I'm afraid you will have to use lamens terms for me. I haven't a clue about the "blocking within the bays" or "diagnonal bracing. We used what I think are concrete nails. (The contractor at Home Depot suggested them) We predrilled holes through the wood and about 2" into the concrete and hammered a jumbo nail with expander thingees on them. (Like I said I'm a rookie. ) The bottom plates wont budge. So we know they are anchored in tight its the top quarter that we can push slightly.
Old 04-01-2008, 02:03 PM   #7
Does it look something like this?
Old 04-01-2008, 02:32 PM   #8
Another, less laborious option is to install a double top plate. The 2nd layer doubling, or "capping-over" the 1st plate. I like Skymaster's idea of using Plywood on the side. We have done that too, when fixing other people's poor framing. You don't necessarily have to do both sides. One side may help enough. Screws and glue are good advice too.
As mentioned, you could use 5/8" Sheetrock. It add's rigidity (as it does with steel framing).
- Build Well -
Old 04-01-2008, 04:55 PM   #9
It just occured to me that this is for a bar. If there is a counter top section going on, "it" can stablize the wall, as well.
- Build Well -
Old 04-02-2008, 03:51 PM   #10
Exactly! The right side is anchored to a wall the left end is not.
Old 04-02-2008, 03:56 PM   #11
Will the counter stabilize even if we don't do cabinetry?
Old 04-02-2008, 06:26 PM   #12
Yes, it should.
- Build Well -
Old 04-02-2008, 10:47 PM   #13
BuilderRemodeler
I like the methods described.
The 4 x 4 method described is a new idea to me I really like.
We have also made a custom metal T with a bottom L flange welded to it attaching to the joists below. While it looks impressive... it all goes back to the adhesive and fasteners attaching it. In most cases it isn't worth the large amount of time and effort... the exception might be if the wall has a lot of glass panels where the plywood and cut in bracing can't be applied.
All of this sounds like it is not really an issue here - As stated - the top attached is securing your wall.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How do I cut a wall in half the right way? sonnycrockett Building & Construction 10 02-18-2008 06:04 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
