Old 06-26-2006, 10:33 PM   #1
Framing Gun - Nail Shank Diameter Questions...
I'm finally making the switch to an air framing gun, instead of doing it by hand.
I am curious about the nail shank diameters for my particular gun though.
Currently hand framing for 8d c.c sinker, shank diameter is approximately 0.110", and for 16d c.c. sinker, shank diameter is 0.145".
For my particular Bostitch gun, and most of the Bostitch framing guns for that matter, the list 2.5" as 0.131" shank diameter. This is larger that what I use hand framing which is fine in my opinion.
However for the 3.5" nails, coated the list 0.131", 0.135", and 0.162" shank diameter. The first two are smaller while the last one seems significantly larger.
I also notice for galvanized 3.5" they only list the 0.131" shank diameter. These I would typically be using for treated wood framing.
Just curious what everyone's thoughts were and what everyone is using.
Thanks for the help. Adam
MoparAutoworks is offline   Reply With Quote
Old 06-28-2006, 08:08 PM   #2
Any thoughts anyone? Adam
Old 06-28-2006, 09:59 PM   #3
Oldguy
Rehabber's Avatar
Most framing nailers and framers use .131 dia 16d nails. They are generally called "16 penny shorts"
If you think you can, or if you think you can't, you're probably right.
Rehabber is offline   Reply With Quote
Old 06-29-2006, 11:22 PM   #4
Old 07-02-2006, 12:47 PM   #5
slave to the house
Bought it recently with some careful consideration. There was also the 752XP model, which seems identical, except it drives up to 0.162" shank diameter. It cannot, however, drive the 0.113" nails (Senco listing), so the higher model drives a "bracket" of shank sizes larger than the lower model.
I did some search for stock availability at my local outlets, and came to the conclusion that the hefty 0.162" is hardly necessary, while the 0.113" is stocked in many ring-shank lengths. Building codes require as much as 16d smooth shank commons, which is actually less than 0.162". That's how I decided to get the 702XP. It was all I needed. The sizes I proceeded to get are equivalents of what the bldg code requires - 10d and 8d - in 0.131" shank, which is nearly identical to the commons. I'm not a professional framer, so this is only my personal analysis.
I would be impressed if your Bostitch can drive the 0.162" *and* the 0.110".
KCnorthernCA is offline   Reply With Quote
Old 07-03-2006, 10:27 PM   #6
Thanks for the advice. I'm having more trouble finding the nails than anything right now, but I think I have found them all.
Thanks again. Adam
More On This Topic
About the Framing Nailer
About the Framing Nailer by Expert Village
This is Brad McMahn for Expert Village. We're going to talk about framing nailers. But first I'd like to get into the different types of framing nailers. This one here is a D-head or a clipped nail, as you can see its got one edge that's cut off and they... Read More »
Golf Shank Tips
Golf Shank Tips by Expert Village
OK, a shank is usually a combination of hitting the ball a little fat with a little slice. And it's really kind of one of those shots like that, people will say I shanked it and they are, I've got the shanks and it's almost like some type of mystery... Read More »
How Much Do Nail Guns Cost?
How Much Do Nail Guns Cost? by Expert Village
This is Rob McMahon with Expert Village. Now, the types of nail guns range with different range of cost and different types of quality. This is one of the top of the line Senco with a clipped head, this runs about $350. The longer magazines are a little... Read More »
Golf Terms: Shanking
Golf Terms: Shanking by Expert Village
Shanking is a golf term used to describe an impure golf shot. Learn more about shanking and how it's used in golf from a professional golf instructor in this free sports video. Read More »
Hi, I'm Kelli on behalf of Expert Village. I'm going to show you my tips and techniques that I use to bridle my horse with a western bridle. So in conclusion when you are putting a western bridle on your horse, you first want to make sure that you pick... Read More »
buying a nail gun with compressor Dave777 Tools 6 10-12-2007 07:11 PM
Framing question(s) civil_corruption Carpentry 2 01-02-2007 12:12 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
