-   -   Framing Gun - Nail Shank Diameter Questions... (http://www.diychatroom.com/f19/framing-gun-nail-shank-diameter-questions-2869/)
MoparAutoworks 06-26-2006 10:33 PM
I'm finally making the switch to an air framing gun, instead of doing it by hand.
I am curious about the nail shank diameters for my particular gun though.
Currently hand framing for 8d c.c sinker, shank diameter is approximately 0.110", and for 16d c.c. sinker, shank diameter is 0.145".
For my particular Bostitch gun, and most of the Bostitch framing guns for that matter, the list 2.5" as 0.131" shank diameter. This is larger that what I use hand framing which is fine in my opinion.
However for the 3.5" nails, coated the list 0.131", 0.135", and 0.162" shank diameter. The first two are smaller while the last one seems significantly larger.
I also notice for galvanized 3.5" they only list the 0.131" shank diameter. These I would typically be using for treated wood framing.
Just curious what everyone's thoughts were and what everyone is using.
Thanks for the help. Adam
MoparAutoworks 06-28-2006 08:08 PM
Any thoughts anyone? Adam
Rehabber 06-28-2006 09:59 PM
Most framing nailers and framers use .131 dia 16d nails. They are generally called "16 penny shorts"
MoparAutoworks 06-29-2006 11:22 PM
KCnorthernCA 07-02-2006 12:47 PM
I have the Senco 702XP
Bought it recently with some careful consideration. There was also the 752XP model, which seems identical, except it drives up to 0.162" shank diameter. It cannot, however, drive the 0.113" nails (Senco listing), so the higher model drives a "bracket" of shank sizes larger than the lower model.
I did some search for stock availability at my local outlets, and came to the conclusion that the hefty 0.162" is hardly necessary, while the 0.113" is stocked in many ring-shank lengths. Building codes require as much as 16d smooth shank commons, which is actually less than 0.162". That's how I decided to get the 702XP. It was all I needed. The sizes I proceeded to get are equivalents of what the bldg code requires - 10d and 8d - in 0.131" shank, which is nearly identical to the commons. I'm not a professional framer, so this is only my personal analysis.
I would be impressed if your Bostitch can drive the 0.162" *and* the 0.110".
MoparAutoworks 07-03-2006 10:27 PM
Thanks for the advice. I'm having more trouble finding the nails than anything right now, but I think I have found them all.
Thanks again. Adam
