Framing A Garage Mudroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 10:23 AM   #1
Framing a garage mudroom
Hi all,
I'm framing a mudroom(15' by 8') in the garage and I'm wondering whats the best way to attach the floor joists to the walls.
1 wall has no drywall on it. the other wall has drywall on it.
On the drywall side:
Should I install a Ledger on the drywall wall and attach the floor joists to it using joist hangers?
On the non-drywall side:
Should I nail a Ledger on the wall studs and lay the floor joists on the ledger and nail it to the wall studs?
Any advice is much appreciated!
Thanks,
Chris
chrishallowell is offline   Reply With Quote
Old 06-11-2010, 01:33 PM   #2
Rewards Points: 5,336
Are the joists sitting on the floor? If they are, box out the perimeter and just shoot the floor joists into the perimeter rim joists. If the floor joists are above the concrete, use the joist hangers.
I would remove the drywall and install all the perimeter banding directly to the house framing.
Ron
Old 06-11-2010, 02:16 PM   #3
Thanks Ron for the response!
The joists will be about 2 feet above the cement floor of the garage.
So are you saying to remove the drywall and use a ledger on both walls. Then use joist hangers to secure the joists to the ledger?
Like this?
Joist ----joist hanger--->Ledger-----Nails--->2x4 wall stud
Old 06-11-2010, 02:24 PM   #4
Like this?
Yes, put a ledger on both sides and remove the drywall. How are you fastening the ledgers to the framing?
Ron
Old 06-11-2010, 03:25 PM   #5
Ron, that was going to be my next question I was thinking really long, thick screws. No idea what size to use.
What should the ledger be made of, 2x6, 2x8?
Any advice on which joist hangers to use or stay away from would be greatly appreciated as well.
I can figure out the joist size using the awc calculator.
This is for a mudroom, which will have a refrigerator in a corner.
Thanks again for all your help.
Old 06-11-2010, 05:33 PM   #6
The ledger should be the same size as the floor joists. I would lag bolt the ledger to the wall using 4 1/2" long, 1/2" bolts and a matching washer. You want to make sure the lag bolt head protrusions do not interfere with the joist spacing and the joist hanger hardware.
Simpson hardware is a good company to use for the hangers. Around here they're in the big box stores and local lumber yards.
Ron
Old 06-11-2010, 09:51 PM   #7
Registered User
Rewards Points: 5,516
I'd run this by your local building department for inspection. If still room for a vehicle, you may need bullards... Converting part of a garage to living space requires code compliance for heat, cooling, ventilation, possible egress, natural or artificial light, etc. (Details will be on your plans).
Be safe, Gary
Old 06-15-2010, 09:27 AM   #8
What are bullards?
Old 06-15-2010, 07:18 PM   #9
jlhaslip's Avatar
Rewards Points: 2,188
bollards are posts typically concrete filled to stop a car
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 06-15-2010, 08:14 PM   #10
Great. Thanks!
Framing a garage loft narsh Building & Construction 3 05-26-2010 08:53 PM
Double Framing on old Garage? bofusmosby Building & Construction 6 04-12-2010 09:08 PM
garage door framing Please help craigcr Carpentry 4 10-18-2009 10:55 AM
Garage framing rotted, back side dropped 3" zetti1102 Building & Construction 12 08-06-2009 08:18 PM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 10:43 PM
