Framing In Floor Void From A Chimney I Removed = Help Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 08:56 AM   #1
framing in floor void from a chimney I removed = Help Needed
I removed an interior chimney at my house that spanned through 2 seperate floors. The space i need framed in on the second floor will be a high traffic area. I searched online for requirements to frame it in but I came up with nothing. Can anyone offer any help? Thanks
dpic05 is offline   Reply With Quote
Old 09-12-2012, 09:46 AM   #2
kwikfishron's Avatar
Rewards Points: 576
Welcome to the forum.
The short version is you need to create full perimeter nailing for the new sub floor patch to attach to. That would likely mean blocking in-between the floor joist and then possibly blocking between those blocks.
Posting a picture would allow us to give you more detailed info for your particular situation. How to attach a photo to a post
kwikfishron is online now   Reply With Quote
Old 09-12-2012, 05:05 PM   #3
Bombastic Idiot
notmrjohn's Avatar
"Posting a picture, blah blah blah.." I suspect every one has some version of that all copied and ready to paste before they even read the question.
Dimensions of opening would be nice too. Don't fall thru the hole while taking da pic, dpic.
notmrjohn is offline   Reply With Quote
Tags
chimney , framing
Baffling chimney issue… hotot Concrete, Stone & Masonry 15 08-28-2012 08:42 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Replacing a Brick Chimney GeauxCajuns82 Building & Construction 4 04-16-2009 07:20 PM
Where a wall meets a chimney joelbuckley Carpentry 12 11-13-2008 03:19 PM
framing out a wall around a chimney pjm Carpentry 12 05-09-2008 07:33 AM
