Framing Ductwork Soffit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 10:22 AM   #1
Rewards Points: 81
I am finishing my basement and I could use a little help. I have started building the soffit around the duct work. A few questions:
1. The flat 2 x 4 is 64" long. Will that support drywall?
2. Is it a problem that there is not a 2 x 4 running lengthwise at the outside edge? (inside the red boxed area)
Thanks in advance!
[IMG]file:///C:/DOCUME%7E1/DON%7E1.SOU/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Framing Ductwork Soffit-basement-soffit-.jpg
OhioDon is offline   Reply With Quote
Old 07-07-2010, 02:09 PM   #2
gmhammes's Avatar
Will you be boxing in the other water and gas line as well? or will that be an unfinished area?
gmhammes is offline   Reply With Quote
Old 07-07-2010, 02:50 PM   #3
Rewards Points: 81
Looking at the top picture, the area to the right of the soffit (where the other water line and the gas line are) will have a drop ceiling.
Old 07-08-2010, 12:12 PM   #4
Rewards Points: 81
Anyone...??? Am I in the correct forum?
Old 07-08-2010, 12:21 PM   #5
Newbie Bill
Rewards Points: 522
You are in the right place. You will get lots of input in the days ahead. I think being summer some of the experts spend a little less time on their computers.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 07-08-2010, 12:34 PM   #6
kwikfishron's Avatar
Rewards Points: 998
Cap that end with plywood. That would hold it all together and you can build off that to cover the pipes.
kwikfishron is online now   Reply With Quote
Old 07-08-2010, 05:33 PM   #7
Rewards Points: 1,760
I did the same in my basement; put T-111 on the vertical portion to match a wall with it on it (just for visual purposes but also adds a lot of strength to the frame). Drywall hasn't sagged in 8 or more years.
bob22 is online now   Reply With Quote
Old 07-10-2010, 06:32 PM   #8
Rewards Points: 81
Drywall will go on this side (and bottom) then the drop ceiling rail will be attached more or less where the purple line is on this picture. What is the purpose of the plywood or T1-11? Can the drywall corner just be nailed into the vertical 2 x 4s since there is no 2 x 4 running lengthwise?
Old 07-10-2010, 07:26 PM   #9
Old School
Willie T's Avatar
Seems no one wants to directly answer your question.
Yes, it can be drywalled as it stands. If it would make you feel better, you could run a longitudinal piece on the insides of the bottoms of the verticals, but it isn't necessary. Just keep in mind you can only fasten the corner bead at the points where you have verticals.
Willie T
Old 07-10-2010, 07:56 PM   #10
Rewards Points: 998
I see a crack running down the corner bead in a couple years Mr. T, don’t you?
Old 07-10-2010, 08:29 PM   #11
Rewards Points: 81
Can you explain how and why it would crack?
Old 07-10-2010, 08:50 PM   #12
Old School
Willie T's Avatar
Drywall compound tends to crack at the back edges of unsupported (un-backed) corner bead. That's why I mentioned that you would only be able to fasten the corner bead at the verticals.
But this drawing shows a possible solution. And it will only take up another 3/4" in soffit width. The bead still might crack on the bottom surface, though this stiffener will help greatly to deter that happening. Solid plywood as mentioned earlier will work too.
Willie T
Old 11-20-2010, 02:14 PM   #13
Rewards Points: 81
I bought 1 x 2 x 8' furring strips. Will these work to run lenghtwise as you suggest? Do I need wider and/or thicker lumber? This would run along the bottom edge so both the bottom and side drywall would be fastened to this furring strip. Framing Ductwork Soffit-dscn2230.jpg
framing around ductwork jcrampton Remodeling 12 08-01-2011 02:31 AM
Slim Soffit for Ductwork in Basement stubits Building & Construction 4 04-28-2010 02:48 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Framing a Wall with a Soffit on Top sethr Building & Construction 2 05-21-2007 08:14 AM
Removing ductwork in soffit... inovermyhead HVAC 2 04-02-2006 10:56 PM
