Old 09-02-2011, 07:18 PM   #1
framing duct
closing in duct in basement
I had hot & cold return duct runing the length of a room. The duct is very close to the door entering the room and I do not have enough room for normal 2x2 plus sheetrock without completely cutting the door down by 3 inches.
Bruce
fifthwheeler is offline   Reply With Quote
Old 09-02-2011, 07:57 PM   #2
fabrk8r
fabrk8r's Avatar
framing duct
You can make, or have made, a transition that is 3" less in depth and wider to accommodate the door and soffit.
I would recommend having the transition built by someone who can calculate the correct dimensions using a ductulator so the airflow isn't compromised. The width may or may not have to be the same amount as the change in the difference in depth because this will depend on the dimensions of the existing duct.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
framing spacing on duct soffit box gdoucette Building & Construction 2 06-11-2010 11:15 PM
duct work framing kama Carpentry 4 11-15-2008 01:40 PM
Framing wall under duct JiD Building & Construction 1 03-31-2008 01:10 PM
