#1 |
Framing a Doorway in the Basement
I am trying to frame a rough opening for a prehung door that I plan to install. First, I am trying to install it under the center beam in my basement. It is not as tall as I would like, so I am wondering if I can get by without using a traditional header. The opening I have after installing framing is around 80". The rough opening for the 80" door is supposed to be 82". I would like to trim the jamb and door to make it fit, if I can do so without needing a header above it. I have included a diagram to try to illustrate the issue.
Second, I believe the base of the door jamb will go directly on the concrete (B) rather than resting on the bottom plate (A). Since it is not treated lumber, is this a problem? Or am I incorrect with where I am putting the bottom of the jamb? Thank you very much in advance for any assistance/advice you can provide. http://www.diychatroom.com/attachmen...1&d=1175120675 |
#2 | ||
Lic. Builder/GC/Remodeler
Framing a Doorway in the BasementQuote:
If you are really concerened, a simple solution is to apply water proof paint over the concrete floor ...or just around the area of the door openings....
- Build Well - |
#3 |
Remodeler
Place a couple neoprene spacers under the door jambs to keep it off the floor. Your going to cut the frame anyway. Might as well get it off the floor another 1/2".
Minichillo's Construction I will never leave you hanging! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Framing a basement ledge | nlexi912 | Building & Construction | 8 | 11-14-2011 05:24 PM |
| Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? | xray328 | Remodeling | 27 | 06-19-2011 09:50 PM |
| basement framing, walls parallel to joists | DIY4EVER | Building & Construction | 8 | 06-06-2007 04:08 PM |
| Basement Framing Question | lpcon | Building & Construction | 7 | 04-17-2007 11:18 PM |
| Need to Cement Up old Basement Doorway | BigArnold | Building & Construction | 1 | 12-29-2006 04:52 PM |
