Framing Door And Window Beneath LVL Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 11:12 PM   #1
Rewards Points: 20
Framing Door and Window beneath LVL Beam
I am framing an addition. I have a beam (double 2x10 LVL's) accross the top. Underneath, there will be a 6' sliding glass door and a window.
Between the bottom of the beam and what will be the top of the door (and window) there is about a 6" gap.
How do I frame the window and above the door? Do I need jack studs and additional headers? Or can i just frame in the rough opening size and put blocking between the top of the frame and the bottom of the LVL's?
thanks!
ms14 is offline   Reply With Quote
Old 08-21-2013, 12:02 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Up to you.
You could just pad it down but you will weaken the R-Value of the wall.
If it is easier, just pad it down.
Old 08-21-2013, 08:33 PM   #3
Rewards Points: 2,212
Run a 2x6 across between the studs at the height needed. Add in little cripple studs (about 4.5" every 4' (in a 6' opening just put one centre.) Because it is under 16" (or 2') you do not need studs every 16".
mae-ling is offline   Reply With Quote
