Framing A Door That Is Butted Up To A Corner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 03:15 PM   #1
Framing a door that is butted up to a corner
How do you put moulding around a door when one side has less than 1" of space to the corner? The only thing I can come up with is some type of cove moulding.
Edited for correct terminology.
kntry is offline   Reply With Quote
Old 08-31-2009, 04:21 PM   #2
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
If you are framing it you control how close to the corner it is. If you are looking to trim it out then simply rip down your casing and install whatever you can. You will also have to cut the top trim piece for length.
Good luck and be safe and if this doesn't answer your question come on back and a picture might help to bring back
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 08-31-2009, 07:57 PM   #3
Sorry, I used the wrong terminology. I fixed it in the post.
I need to know how to put the moulding around the door when there's less than an inch of space.
Thanks for the help.
Old 08-31-2009, 10:03 PM   #4
Paragon's Avatar
Rewards Points: 150
do you by chance have a pic?
James D. Van Raden
Old 09-01-2009, 08:33 AM   #5
No, but I can get one tonight and post it.
Old 09-02-2009, 08:22 PM   #6
Here are the pics of both doors in question.
Framing a door that is butted up to a corner-door-jam.jpg   Framing a door that is butted up to a corner-door-jam-brandon.jpg
Old 09-03-2009, 06:01 PM   #7
GC
Go with Paragon's answer, You have to rip the side trim to the width you need and then cut the end off the top piece accordingly!
Spotfire is offline   Reply With Quote
Old 09-04-2009, 08:52 AM   #8
Jay123's Avatar
If you're not VERY comfortable with a table saw, find someone who is...and is comfortable ripping a 1" piece...it's easy IF you've got the experience, otherwise it's an accident waiting to happen. Good luck.
Jay123 is offline   Reply With Quote
Old 09-04-2009, 09:41 AM   #9
Jay123's Avatar
This may help...
Old 09-04-2009, 09:57 AM   #10
Paragon's Avatar
Rewards Points: 150
Very good info Jay. Another thing they could do to mark where to cut that top piece of trim is flip it upside down so that the nub they are going to cut off is to the right. Then they can mark their 3/16ths reveal inch line on the right side of the jamb and then transfer the mark from the jamb to the trim go to the miter saw and give it one cut and go back and install it. OR they could just use a tape measure too, lol.
Great diagram btw what program is that done with?
Thanks and have a great day!
James D. Van Raden
Old 09-04-2009, 10:10 AM   #11
Jay123's Avatar
Thanks James, it's chief architect. I just posted some info on this thread regarding it...great tool.
Software for computers, involving house plans
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
