Framing A Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2005, 09:02 AM   #1
framing a door
I am finishing the rest of my basement and started to put up NON LOAD bearing walls.
I noticed that the walls that the contractor built in the basement have no jack studs in doorways and the header is attached directly to the king studs.
Is this normal? is there a disadvantage to doing this for the rest of the basement?
Why do you even need a jack stud in a non load bearing wall?
lexar is offline   Reply With Quote
Old 03-10-2005, 11:27 PM   #2
framer
no youdo not need any jack studs or"cripples" in the basement walls but most contractors would just to keep their doorways solid and plumb but he may have framed that way to conserve on materials
sandy kiemele is offline   Reply With Quote
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 12:50 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
