Framing Closet - Header ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 10:02 PM   #1
GBunny
Rewards Points: 71
Framing Closet - header ?
After having problems with a few contractors, I've decided that a woman can do this job too. My closets had floor to ceiling sliding doors and I'm going to attempt building a header and changing the opening to accommodate either bifolds or prehung doors - is one better than the other?
Have I figured out the measurements correctly?
43" opening
-8" (2 king & 2 jack studs)
-30" door
5" remains
How much bigger does the opening have to be than the door - 1/2"?
Do I put the header at 82.5"?
What is the best way to fill the extra 4" or 4.5"? Put in a couple more studs and some shims?
Is it easier to make the frame on the floor or just build it on the walls?
Thank you.
GBunny is offline   Reply With Quote
Old 03-27-2010, 11:24 PM   #2
jlhaslip's Avatar
Rewards Points: 2,728
Since the previous doors went floor to ceiling, you really should not need a structural header for the replacement doors. The closet door opening must be a non-load bearing wall, or the header would already have been in place.
Add 2 inches to the width and height of the door SLAB when laying out the door rough opening. Standard RO size for a 30 inch door is 32" wide by 82" tall to the underside of the RO header. The cripples will be 80 1/2 inches tall sitting on the 1 1/2" bottom plate.
When doing your calculations, note that a 2 x 4 is actually 1 1/2" by 3 1/2" after drying/jointing/planing. The 2 x 8 header is actually only 1 1/2 by 7 1/2 inches.
Fill in the top of the header with short lengths of 2 by material on 16 inch centres for drywall nailing.
Attached is a drawing showing the infill wall assuming a 43" wide opening changed to fit a 30" slab door. Note also that bifold doors are commonly shorter by an inch, so you are better to use this full size and shortening the height later. It is easier to fill-in the opening rather than the other way.
[edit]
I actually use 82 1/2" cripples and fill under the header using the door opening bottom plate after it is cut out. The door cut-out is used as a place at the bottom of the header to nail drywall and the door casing on trim-out. Works better, but the drawing does not show this. You will need to use a piece of 2 by material on edge to allow for nailing inside the opening or adjust the measurement of the cripples to allow for this taller cripple, etc.
[/edit]
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-27-2010, 11:27 PM   #3
jlhaslip's Avatar
might be able to see the dimensions better in this image.
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 08:11 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
How do I Lower Closet Header? cheapchick Carpentry 15 08-31-2009 07:50 PM
correct window framing? incorrect header jingles63 Building & Construction 2 05-02-2009 01:49 PM
Closet Header SDL Remodeling 5 02-05-2009 01:53 PM
