Old 11-27-2012, 07:42 PM   #1
JOATMON
ddawg16's Avatar
Framing Clip? Uneven Wall?
I need to install framing clips (LPT4's) on a shear wall.....this wall 'used' to be the back wall of the existing house....so off came the stucco....peeled back the roof....tossed a 3.5"x11.25 PSL beam on top of the top plate.....and then nailed up 1/2" struct 1 OSB.
Seeing how this is a "C" shearwall...I need LPT-4's every 12".....
As you can see in the pic....if I nail the LPT to the OSB....it sticks out 1/2" from the beam......
I've already bugged my architect way tooooo many times....but I seem to recall him saying to just nail it on top of the OSB...
So...confirm...I just nail to the OSB....smack the LPT with a hammer and nail the top portion to the beam?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-27-2012, 08:11 PM   #2
Moderator
kwikfishron's Avatar
Add a layer of OSB to the beam to flush it out then install the clips.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joecaption (11-27-2012)
Old 11-27-2012, 08:48 PM   #3
funfool's Avatar
kwikfishron is right,
When I first saw photo, I would span the osb over the joint to tie them in.
Would have started from top of beam and span over the beam, then piece in the bottom.
But I still think something is wrong with this picture, cant quite put my finger on it.
If you put the clips on first, then spanned the joint with osb, that would make sense to me.
Putting the clips over the osb makes no sense
I would need to see the plans, would it be osb on one side and clips on the other side?
Been more then once had city approved plans from the architect, end up having to make revisions on them and approved from city, simply looking at them make no sense.
You at least need osb on the beam so clips will be flat.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
Old 11-27-2012, 10:35 PM   #4
You can add 1/2 OSB over the Parallam beam and then nail the LPT4, but you must use nails that are longer than Simpson specifies for the clip, I believe 8d common nails will result in no load reduction. Do not bend the LPT4. You can call Simpson with questions, I have found they have very good support.
TheCamper is offline   Reply With Quote
Old 11-28-2012, 01:06 AM   #5
JOATMON
ddawg16's Avatar
In retrospect....I wish I had put the OSB on after the beam was put in place.....but I had the back wall exposed and needed to get it covered.....seeing how it was 2-3 months before the beam got put into place....
I just happen to have a 10' length of OSB that is only about 5" wide.....I think it will work perfectly.
Thanks guys.
My
and
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Framing an interior wall jrowny Remodeling 4 05-21-2010 09:43 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 01:03 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
