Old 04-04-2012, 09:24 AM   #1
Framing Clip
I am researching some basement wall "methodology". I can build walls and all but I'm interested in the L-shaped framing clips as typically used on a basement wall connection to the joist at top of wall. I understand the implementation of the clip for allowing heaving & expansion of the concrete basement floor etc. The clip is usually described as an L-shape that nails to the top of the wall and has slits in the vertical leg that nail to the joist. Can anyone provide an image or link to such clip. I can't find anything that matches that description. Is this a clip specifically for this purpose, or is their a generic clip that framers use to serve this purpose?
kevsprojects is offline   Reply With Quote
Old 04-04-2012, 09:29 AM   #2
Framing Clip
http://strongtie.com/products/CFS/SCW.asp
Old 04-04-2012, 09:47 AM   #3
Framing Clip
Thanks, that's a good reference for steel studs. Is their another version for typical 2x4 wood framing also?
Old 04-04-2012, 09:50 AM   #4
Framing Clip
Just look around on that same web site. Your looking for slip head wall clips.
Old 04-04-2012, 10:09 AM   #5
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Framing Clip
Maybe THIS one?
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Old 04-04-2012, 10:14 AM   #6
Framing Clip
That one would not allow for the wall moving up and down as the slab heaves.
AndyGump (04-04-2012)
Old 04-04-2012, 11:24 AM   #7
Framing Clip
Maybe this one?
http://www.strongtie.com/products/co...TCT-DTC_PT.asp
jrepp44 is offline   Reply With Quote
Old 04-04-2012, 12:40 PM   #8
Framing Clip
jrepp44, YEA! I'm sure that's it. There may be others and I'll look when I have more time but that would work for anything I would be doing.
Thanks,
Kev
Old 04-04-2012, 05:09 PM   #9
JOATMON
ddawg16's Avatar
Framing Clip
Kev....download the Simpson catalog....it's well worth having on your comptuer.
You might also want to see if there is a building supply near by....and I don't mean Lowes of HD. I'm lucky in that there is one a mile from me....free Simpson catalogs....I have two...one stays in the bathroom.
From your initial description I was thinking you were talking about huricane ties....they nail to the top plate and have a slot for the rafter or ceiling joist to sit in.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 10:12 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
