Framing Between Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 08:18 AM   #1
Rewards Points: 252
Framing between windows
I'm trying to figure out the framing in a new addition and have several windows side by side (about a 4' rough opening). Can I eliminate the second king stud so I have the following: trimmer to support the left window header, King stud, trimmer to support the right window header. Or should I keep it so I have trimmer, king, king, trimmer?
shazapple is offline   Reply With Quote
Old 07-05-2012, 10:05 AM   #2
Rewards Points: 2,212
You also need to think about the outside brickmould and siding and the trim inside.
Not sure if it will meet code for you, here we can run a continuous header and then put trimmers underneath it to go between the windows.
mae-ling is offline   Reply With Quote
Old 07-05-2012, 06:58 PM   #3
Framing Contractor
All you need a single king stud with one trimmer on each side. Or if you don't want 4-1/2" in between you can frame a big enough header for both windows with 2 - 2x4s in between giving you 3" .
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-05-2012, 08:21 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
as mae-ling and Joe mentioned, one solid header with either a single stud spaced between the windows or a double stud between the windows. it might be easier this way instead of headers for every window...
hand drive is offline   Reply With Quote
Framing exterior windows. thunderhead Carpentry 1 07-04-2011 07:05 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 08:07 AM
Framing in New Windows to enclose a porch DDRowe Building & Construction 2 05-25-2005 07:05 PM
