Framing Between Load Bearing Columns - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 08:59 PM   #1
Rewards Points: 115
Framing between load bearing columns
Hello everyone!
I'm looking to take down a wall (or most of it) between my living room and kitchen, and put in a center island with half raised counter top and bar stools on the living room side of it.
This wall is a load bearing wall and there are two steel columns going down to the basement and attaching to the foundation.
My question is: can I rip out the drywall and 2"x4" framing between these two columns without negatively affecting the structural support of the house? Is the 2"x4" framing doing anything except to put up drywall and possibly hiding utilities? Or is this a case by case basis and I need to hire a structural engineer to tell me?
I'm debating whether to hire out and have a contractor put a beam in and take out the columns ($$$), or if I should just build the island around the columns. I'm leaning more towards option #2.
Thanks for any help you can provide!
6fthook is offline   Reply With Quote
Old 12-19-2010, 11:52 PM   #2
Rewards Points: 1,092
I think you answered you question with an emphatic "No" when you said "...This wall is a load bearing wall..." To remove it, you'll have to do a lot of work to temporarily support what the wall was supporting, then install something permanent to do what the wall was doing, like a beam. That could generate real work all the way through the basement floor. I don't think you'll get anyone sticking there neck out w/out seeing the whole system. Sorry, but a load bearing wall is a serious structure, in my book. Good luck w/ it. j
Old 12-20-2010, 04:56 PM   #3
if u go with option #2, r the beams u r planning on building around supporting the load bearing wall? or is the 2x4 wall that u r planning or tearing supporting the load?
rkling is offline   Reply With Quote
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
damaged load bearing stud, next to a window danf01 Carpentry 1 10-12-2009 06:02 AM
Load Bearing Half Walls??? HoneyDo007 Building & Construction 5 10-04-2009 11:53 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
