Framing A Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 08:04 PM   #1
Framing a basement
I am finishing my basement. My exterior walls are 2x6 construction. Can I use 2x4 to frame out interior walls.
I have to frame in around my ceiling forced hot air ducts. Is there any minimum clearance that I need to have.
Is there somewhere that I can find these building codes in writing. I am in Massachusetts.
Jaredlgoldman is offline   Reply With Quote
Old 08-01-2011, 08:47 PM   #2
Framing Contractor
Call your building department, you will need permits anyway.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-01-2011, 09:26 PM   #3
Experienced
Jackofall1's Avatar
Welcome Jaredlgoldman, to the best darn DIY'r site on the web.
2x4's are fine for framing and generally 1" clearance is needed from the supply air duct.
There are requirements in some areas for fire blocking that will need to be adhered to, either the local library or building department will have the specific code answers you are looking for.
Mark
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Insulate split framed/poured basement wall, prior to framing... pasichnyk Building & Construction 9 12-20-2010 06:32 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 01:06 AM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 07:07 AM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 09:38 PM
