Old 11-29-2006, 06:59 AM   #1
framing an awning...quick question
Im framing a shed roof awning coming off of the back of my house. it will extend out about 15 feet with a pitch of about 3 or 4. What sixe lumber should I use? @ x8 of 2 x 10"? This is for shade. There will never be anything built on it...Just roof and snow load.
Also, there is a concrete patio about 6" think. Can i just teco the posts onto the patio or should I pour some footings. Thanks in advance
sjrhome is offline   Reply With Quote
Old 11-29-2006, 09:39 AM   #2
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
If you have a snow load, you have frost.
You can expect the slab to come up and down during the seasons. so getting a good attachment at the house will be difficult if you want it waterproof.
If you put a ledger on the house, take off some siding and install flashing. If not, you could have a leak into the house with moisture, rot, mold, etc.
concretemasonry is offline   Reply With Quote
Old 11-29-2006, 10:32 AM   #3
For light to moderate snow load, 2x8 rafters on 16 inch centers
should be OK. Be sure to install at least 1 row of solid block
bridging...2 would be better with a 15 foot span.
With such a long span, I would also sheath with plywood
instead of OSB.
I would also recommend digging for some type of footing support
below the local frost line. If you don't, you risk cracking of
your patio due to frost heaves and the extra weight of the awning.
If you want your posts mounted to the patio surface for reasons
of apprearance, dig holes under the patio at the points where
you will have posts and fill with concrete.
jbob is offline   Reply With Quote
Old 12-01-2006, 09:38 PM   #4
I have two additional questions but this may be a roofing question how do you seel this to keep it from leaking when adding a tin roof to brick exterior as if to add a garage flashing i am sure but, but i need more detail. thank you just, found this site, this place is great.
neslaf is offline   Reply With Quote
Old 12-02-2006, 10:33 AM   #5
Hi,
I've done it as illustrated below
I'm not a professional roofer, so there may be an easier way.
With a 4 inch grinder I grind out the mortar of the right course
of brick about 1 inch deep. Have flashing fabricated (not very
expensive), Insert top of flashing into groove in mortar, tuck
new mortar into groove, install comp roofing. Seal top course
of roofing to flashing with NP1.
May be completely different for metal roofing, but this may
give you an idea
Old 12-03-2006, 07:36 AM   #6
In your drawing, you show the flashing laying under the roofing. It should sit on top of the roofing.
Old 12-03-2006, 10:49 AM   #7
The NP1 seals the flashing to the roofing for a better appearance.
The NP1 is so tough, it will outlast the roofing.
Old 12-03-2006, 12:24 PM   #8
Thumbs up
i just wanted to say thank you for all of the help and information. This place is great and hope that all of your projects are full of fun but not to much excitement.
More On This Topic
Determining where you are going to put a new patio is just the first step in making this addition to your home. After you figure out just where the patio will be, it's time to start prepping for the project. There are a few things to think about during... Read More »
Creating an inviting outdoor space by building a patio is a great idea, but can become a great headache if not well thought out. Put together a budget and develop your project plans before getting started and your wallet and home will thank you for it. Read More »
Awnings provide shade from the sun, protection from bad weather and a form of advertising for a business. Proper cleaning of your awning can keep it looking like new for many years. Read More »
Patio chair cushions can make your furniture more comfortable and attractive and can transform your outdoor space. They offer an easy way to personalize your space and reflect your style. Swap out the cushions for a change in seasons and for special... Read More »
Alright, so now we have all our pots planted and where do we put them, what kind of light do they need? Generally I would put the cactus in the sunniest window, probably like a south facing window, they're going to want a lot of sun. These fleshier... Read More »
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 08:36 AM
Framing question dtmbizzle Building & Construction 4 06-14-2007 09:40 PM
Basement Framing Question lpcon Building & Construction 7 04-17-2007 11:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
