Old 07-08-2010, 05:42 PM   #1
Framing around ducting - alberta building code
I'm dropping a ceiling in a bathroom to cover some ductwork, and am not sure how much space I need to keep between the duct and my framing.
Anyone in Alberta know what's required?
Also, I'll be running the boards on the flat to keep as much height as I can. My bathroom is 5' wide. How long can 2x4's on the flat run before they need to be supported in the middle? Supports are not an option, as the ducting prevents me from gettin up anything into the joists.
Thanks in advance.
basementsweet is offline   Reply With Quote
national building code book smallcrpt General Discussion 2 11-13-2007 08:09 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
sewage building code for home owners aokss Plumbing 9 09-11-2006 07:37 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
