Framing Around 4" Metal Pole - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 08:34 PM   #1
Framing around 4" metal pole
Hello All,
I am in the middle of framing my basement and planning out an interior wall. There is one metal pole with a diameter of 4" I plan to frame into the wall, but since it is a 1/2" wider than the standard 2X4, I need some help with this. If I use a 2X6, how do I frame the door? Looking at a neighbors basement (same layout), I believe all of the doors were the same depth.
Thanks,
Brent
xlr8tn is offline   Reply With Quote
Old 01-14-2008, 08:39 PM   #2
Electrician
Originally Posted by xlr8tn View Post
Hello All,
Thanks,
Brent
You would use extension jambs
chris75 is offline   Reply With Quote
Old 01-14-2008, 08:41 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You don't necesssarily have to jump all the way up to a 2x6. If you need an additional 1/2" or more, you can do rips of 1/2" plywood or strapping, and attach them onto one side (or both sides) of your framed wall studs.
As far as dealing with a large width door jamb...if you are using pre-hung doors, you can simply fabricate stock to make your own "extension jambs".
Example:
- Build Well -
Old 01-14-2008, 08:58 PM   #4
cool...thanks for the pics and info. So if I understand what you are saying, I should just frame my normal 2X4 studded wall up to the pole and then continue on the other side. To account for the pole sticking out 1/2", I should then put plywood on the inside of the wall so my drywall will be flush. I can then buy a normal door, but add the jamb extensions to close the gap.
-brent
Old 01-16-2008, 08:39 PM   #5
Rewards Points: 150
Or, when you order the door, order a thicker jamb. Or by a 2x6 jamb and cut it down.
kgphoto is offline   Reply With Quote
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
metal framing davidfenton Building & Construction 8 07-07-2006 07:20 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
