Framing An Angled Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 03:07 PM   #1
framing an angled wall
I am not sure how to frame for a 45 degree angled wall. The frame will float on treated lumber, that is attached to the concrete floor and the frame is attached to the rafters. I can angle the top & bottom, just not sure how to get the vertical corners angled so we can attach to the drywall.
KimMB is offline   Reply With Quote
Old 11-16-2011, 04:34 PM   #2
Rewards Points: 55
Attach the new wall to existing drywall? Or are you talking about hanging drywall on the new wall?
I did this without much forethought and remedied any problems after the wall was up. That basically meant the I nailed in some 1x4 and 2x4 material wherever required to fasten the drywall.
jkeuning is offline   Reply With Quote
Old 11-16-2011, 08:25 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
im guessing this a neo angle wall. post a picture or sketch of what it is exactly your trying to do
woodworkbykirk is offline   Reply With Quote
Framing on top of poured concrete wall Mikeymannii2 General DIY Discussions 2 05-08-2011 06:36 AM
Basement wall framing with baseboard heaters gregkfraser Building & Construction 3 11-14-2010 09:35 PM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 08:38 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 12:03 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
