Framing An Angle Wall??? Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 11:31 AM   #1
Framing an Angle wall??? Help
Hi, i am renovating my house and want to frame in an opening to turn my now dining room into a bedroom. Problem is the wall will have to be on an angle. I need help how to figure out the angle i will require to tie the walls together. the measurements of the opening are: From Outside tip to outside tip 50". Inside tip to inside tip 44 1/2". This is a little vague but i hope you can understand what im trying to do here. Thanks!
I have a drawing of the opening but im not sure how to upload it here...
Debonis is offline   Reply With Quote
Old 02-25-2012, 11:32 AM   #2
I lied
Here is the opening
Old 02-25-2012, 11:39 AM   #3
Rewards Points: 13,216
Why not just lay out those dementions on a 2 X 4, set your saw to the angles you marked and do a test fit.
Old 02-25-2012, 11:48 AM   #4
Wow
HAHAHA, wow i feel dumb, yea that would work perfectly. I have been working nonstop for like 3 weeks...mind is mushThanks bud!
Old 02-25-2012, 11:55 AM   #5
If I had to know what the angle was I would use one of these.
http://images.search.yahoo.com/searc...tarrett+505a+7
I'd set 2, 2 X 4's againt the outside walls to use as a referance point.
If those old walls have sheetrock returns your going to have to remove the old metal outside corners to tie in the new sheetrock.
I'd use the sheetrock tape with the metal bands built into them to form the new corners.
Old 02-25-2012, 12:52 PM   #6
Old School
Willie T's Avatar
In case you still might want the degrees...
Willie T
Tags
angle , walls
Crown angle for slanted wall emaxxman Carpentry 9 01-15-2012 01:29 PM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 01:15 PM
Basement wall framing with baseboard heaters gregkfraser Building & Construction 3 11-14-2010 10:35 PM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 09:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
