Framing an Angle wall??? Help
Tags
angle walls
13K views 5 replies 3 participants last post by  Willie T
Hi, i am renovating my house and want to frame in an opening to turn my now dining room into a bedroom. Problem is the wall will have to be on an angle. I need help how to figure out the angle i will require to tie the walls together. the measurements of the opening are: From Outside tip to outside tip 50". Inside tip to inside tip 44 1/2". This is a little vague but i hope you can understand what im trying to do here. Thanks!
I have a drawing of the opening but im not sure how to upload it here...
#5 ·
