Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 10:05 PM   #1
Framing
I have a friend buying a new home (new construction). We were doing a walk through (pre-drywall) and noticed a few of the studs had vertical fractures. The builder said this should not be a problem because these are not load bearing walls. My thoughts were if it were my home I wouldn't want to see any cracks in the framing.
We would appreciate any feedback from any of you knowledable members of DYI. Thank you in advance.
as2637 is offline   Reply With Quote
Old 02-28-2011, 11:12 PM   #2
If the wall is not load bearing, I won't worry about it.
If it's a new house, there should be a new home guarantee. And the worst that can happen is that the stud will twist or bow.
Dante1
dante1 is offline   Reply With Quote
Old 03-01-2011, 08:27 AM   #3
Rewards Points: 5,336
It depends on the severity of these defects. Are they small checks or splits that run down the stud?
What grade studs were being used? Were they "green" studs. These have a high moisture content and unless braced will distort over time. When they do, they will cause issues with the drywall. There's also air dried lumber and kiln dried lumber. Kiln dried has the least moisture and I use these when I frame walls.
If you can, take a photo or 2.
Ron
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
How do I find a framing contractor in Rhode Island christy123 Building & Construction 2 10-25-2006 11:29 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
