Old 01-07-2007, 04:10 PM   #1
yummy mummy's Avatar
Framing 2 concrete posts in middle of basement
I have 2 concrete posts in the middle of my basement that are approx. 15 inches X 15 inches.
How do I frame around them in order to later install drywall?
Do I treat it like a wall and do top plate, bottom plate, etc.?
Or is there another way to do it?
They are made of concrete blocks, and not really smooth and straight.
If I just attached wood strapping to them, will the wood crack when drilling into the concrete and using Tapcon?
Thanks for any help.
yummy mummy is offline   Reply With Quote
Old 01-07-2007, 04:31 PM   #2
remodeling pro
Tapcons will certainly work , but I find them to be lots of trouble in cinder block because the diameter of the hole is critical to their success and block does not drill nice clean holes in my expeiences. I would use #10/12 plastic or lead anchors and deck screws. Clamp the 1 x4 in place to form a plumb outside corner from left to right, and drill through it to mark the location of the hole on the post, remove the wood and drill and install the anchors. Drill a 3/16 clearance hole in the wood for the screw shank; this will allow you to slip wood shims between the wood and concrete block to plumb the wood from front to back. Use dry, straight wood, and bed them in construction adhesive. You can fill in between the corners at top and bottom with pieces just glued in place (shim out if needed to flush with corner boards), as they are just providing nailing for base and crown trim.
troubleseeker is online now   Reply With Quote
Old 01-07-2007, 04:41 PM   #3
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
When drilling into and attaching to concrete block or brick, try to drill into the mortar joint.
Brick properties vary wildly and it is easy to crack a very strong, hard red brick while a soft red brick may not have the holding power.
Concrete block usually is more consistant (unless someone wants to make 8,000 psi block), but the aggregate varies and coarse aggregate can be difficult to get a uniform diameter hole in.
The mortar is much more consistant and predictable.
concretemasonry is offline   Reply With Quote
Old 01-07-2007, 05:27 PM   #4
Thanks for the info.
Will try the suggestions.
Hopefully, will work.
Old 01-07-2007, 07:18 PM   #5
Remodeler
MinConst's Avatar
I would use a standard framing method. Use 2x2s and be done with it. Straight and easy 8 uprights and the top and bottoms are all it will take.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 01-07-2007, 09:43 PM   #6
Do you mean, the usual method of top plate (2X2s) and bottom plate (2X2x) and then the studs in between using 2X2s?
Old 01-07-2007, 10:22 PM   #7
Remodeler
MinConst's Avatar
Yes that's what I mean. You won't be drilling and possibly harming the block with all the tapcons or other fasteners.
Web
One Man Shops
Old 01-07-2007, 10:32 PM   #8
You know what MinConst., I like your idea the best.
And since I already know all about top plate, bottom plate, toenailing, etc., I will know what to do and it seems to be the easiest way to go,
even though I am getting real good at installing bottom plates, (pressure treated of course) using tapcon.
I have a really nice hammer drill that goes into the concrete floor really nice, even though the concrete floor is approx. 70 years old.
Thanks for your help.
Old 01-08-2007, 11:05 AM   #9
seeing two stand alone post in the basement is kind of odd, if you, by any chance to arrange the post being embedded onto some dividing wall or half wall, it will be good... unless you want your basement so opened that there is no inside wall at all...
KUIPORNG is offline   Reply With Quote
Old 01-08-2007, 11:05 AM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
MinConst is right. That's the only right way to frame it.
-my 2 cents-
- Build Well -
Old 01-08-2007, 03:15 PM   #11
Thanks Atlantic.
I was kind of missing your response.
Old 01-08-2007, 03:17 PM   #12
What you suggested is a good idea, but what I want to do is leave the room open.
I also plan on putting trim around the posts so they will look like I wanted them to be there.
I hope they will turn out nice.
Thanks Kui****g
Old 01-15-2007, 08:31 PM   #13
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Hey Yummy Mummy, I am finishing my basement and have two posts as well. Mine are much smaller (4 inch round metal). I am just going to build a box out of poplar. No studs, no drywall. I will paint to match the trim. Will probably also have a baseboard on it to make it look more anchored. 15" sq is kind of big but you could still do in wood. Use a biscuit joiner and wood glue to join 2 8" boards together then miter the edges on a table saw, biscuits, glue and a few brads to hold it together while the glue dries.
Brik is offline   Reply With Quote
Old 01-15-2007, 10:13 PM   #14
Hey, what a great idea.
Then I wouldn't even have to drywall it.
The only thing, how would I adhere it to the concrete.
I get how to build it, but how do I attach it?
Thanks for another suggestion.
Old 01-15-2007, 10:49 PM   #15
Handyguy
Brik's Avatar
Attach a piece of PT to floor that measures the inside dimension of the post surround and use finish nails to attach to that. Same on top but pt not needed on top. Even easier would be to use some tapcon screws on an angle and screw right to the floor then cover with baseboard moulding. Or plastic anchors into the columns themselves at bottom and cover with trim. Same on top and cover with a crown moulding.
More On This Topic
Hi! I'm Danny Ramirez from Tampa, Florida on behalf of Expert Village. I will be showing you how to maintain and use a drill press. First I will be showing you about wood bits. This is a block of wood. You an actually use a variety of bits for wood bits... Read More »
If you need to cut an opening, no matter what the shape or size, within a piece of wood or metal, there is a simple procedure that will make this easy for you to do! Read on to learn how. Read More »
To begin our puppet theater we need to prepare our center theater board. Now I've had this cut in a wood shop and first I've measured around one inch around the frame. So if you measure the inch and the inch and draw a line on your two markings and then... Read More »
Hi, I'm Doug, I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now we've got to drill a hole in our brand new engine in order to mount that oil pump pickup. We... Read More »
Reading the break on the green when you're playing golf can be an impossible task. You must consider whether it is breaking or sloping and if the green is running fast or slow. By using your putter and your good eye, you can answer many of those... Read More »
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 31 01-03-2009 12:33 PM
Pressure treated posts set in concrete? zubin6220 Carpentry 9 08-23-2007 09:42 AM
Framing a basement ledge nlexi912 Building & Construction 7 07-07-2007 09:38 PM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 5 05-06-2007 06:22 PM
Leaking Basement - Concrete jeepwillies Building & Construction 2 03-06-2007 08:42 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
