Framing 1.5 Story Exterior Walls. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 02:16 PM   #1
Framing 1.5 story exterior walls.
Framing a small 1.5 story cabin. 16'x28' 2x6 walls on 16" centers. exterior walls are 14' tall. Cant decide which is the best way to frame the walls. Option one is to set a ledger into 14' 2x6 walls and set the 2x12 floor joist on the ledger and bolt to the 2x6 studs. Option two is to build a second floor and set it on the top plate of the lower floor. and then build a 4' knee wall on the seconf floor and set my rafters on that.
im in marion county florida
OPTION 1.
OPTION 2.
INFALLIBLE1 is offline   Reply With Quote
Old 03-13-2011, 03:13 PM   #2
Love for Construction
<*(((><'s Avatar
I'm assuming the outside is going to be sheathed, if this is the case I would lean towards option 2. It seems like you would get better support for the second story having the joists bearing on top of the wall with a double top plate tying everything together. Then with the sheathing you can tie the kneewall into the bottom wall and rim joist.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-13-2011, 03:39 PM   #3
outside will be sheathed with 5/8 ply and siding will be 5/8 cypress bevel siding.
Old 03-13-2011, 05:38 PM   #4
The rim joist around the second story floor joist seeing that its 28' foot and i cant get a 2x12 in that length there will have to be a seam. Do i just use a but joint? and not put a joist over the joint and to one side or do i position the joist over the joint?
Old 03-13-2011, 07:25 PM   #5
Registered User
Rewards Points: 5,498
Just a butt joint on the rim board, not required at joist; http://publicecodes.citation.com/ico...002_par025.htm
However, FL requires stud to rafter and stud to stud above positive connection (think metal) due to high winds. Check your City/county web site for additional requirements.
Be aware with knee walls or balloon:http://www.unified-eng.com/ch/thrust.html
http://www.smandf.com/25-Conventiona...&Solutions.pdf
Your high wind location may require stronger than 90mph sheathing; http://www.awc.org/pdf/WFCM_90-B-Guide.pdf
Your B.D. will have all the requirements including braced wall panels; http://publicecodes.citation.com/ico...002_par031.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
INFALLIBLE1 (03-13-2011)
Old 03-13-2011, 09:45 PM   #6
Gary
Thank you for the info. Thrust looks like it will be the biggest issue to overcome.
Old 03-13-2011, 11:39 PM   #7
Have decided to use a ridge beam instead of a ridge board this should fix my thrust issue. 5.25"x16" glue lam beam 890 installed.
Now i need to figure out a header for the gable end do to a rather large window i would like to place there.
Old 03-14-2011, 08:00 PM   #8
Registered User
Are the gable rafters continuous or pieced above? If full length, header would carry gable framing- no roof load; http://resourcecenter.pnl.gov/cocoon...er/article/125
http://www2.iccsafe.org/states/Flori...20Material.pdf
Gary
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
2nd story bathroom, drain &vent, please help!!! serik Plumbing 4 07-15-2009 07:33 AM
Reactions to Timeline for Framing Addition austinbirdman Building & Construction 6 01-19-2007 01:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
