Framed Basement Walls Are Not Flat Against Exterior Walls: How To Insulate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 06:00 PM   #1
Framed basement walls are not flat against exterior walls: how to insulate?
The concrete foundation walls on my 100 year old house are not plumb. I recently had the basement framed to finish it. There's probably 6 inches at the top between the exterior wall and the framing at the top, and 3-4 inches at the bottom. I was planning on using fiberglass bat insulation. (This is not a house that I'm going to stay in for more than a few more years, but I do want to do it right if I'm going through the trouble.) Should I put in two layers of 3 1/2" bat insulation or buy some of the 6" fiberglass insulation? Or is there something else that I need to do?
Thanks!
jjcatal is offline   Reply With Quote
Old 07-16-2011, 06:10 PM   #2
DIY staff
Rewards Points: 7,174
Leave the gap behind the wall open---a little ventilation for the foundation is good.
Just use R-13 or R-15 faced bats and staple them into place.
Repainting Basement Walls dnt Painting 15 01-14-2011 01:45 PM
Advice about Waterproofing Basement Walls Firehawk734 Remodeling 2 12-08-2010 03:23 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 06:27 PM
