Frame/Soffit For Pipe In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 10:53 AM   #1
Frame/Soffit for pipe in basement
I am trying to figure out the best way to frame our main sewer pipe in our basement. We are trying to finish the basement, but I struggling with the pipe and the pitch.
The main sewer pipe runs along the walk-out basement wall. It has a pitch to it. I would like to try and soffit the pipe, but also be able to have it properly fireblocked, as the building inspector mentioned all soffits need to be fireblocked.
I have attached a photo, but trying to get some ideas on how to properly frame the pipe.
thanks,
ddave23 is offline   Reply With Quote
Old 11-10-2011, 12:05 AM   #2
Registered User
Rewards Points: 4,936
Build a horizontal chase, fire-blocking it from the ceiling (floor) cavities above and the wall cavities below as per: How to fireblock framing
Gary
Old 11-10-2011, 04:30 PM   #3
Thank you for the information.
So to build the chase, should I box out the pipe with with 2x3s?
To fireblock the soffit/chase, should I use plywood to block the vertical wall section or the ceiling section in the chase? Or do i block both?
Old 11-11-2011, 10:31 PM   #4
Registered User
Page 4- # 50-51 pictures.
Gary
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
