Just purchased a home in northern lower michigan. A frame 11/6 pitch 2x6 4' o.c. 1/2 loft. It seriously lacks insulation. My understanding from the individual that built it originally the construction inside to outside is exposed 2x6 4' o.c., 1" knotty pine t&g, 1" styrofoam, plywood, shingles. The two choices I'm facing are
1. placing insulation in between the exsisting 2x6 and redoing the interior(most likely drywall) or
2. removing the shingle, plywood, styrofoam combination and insulating over the exsisting rafters/t&g. I prefer the latter as I really don't want to loose the rich look of wood inside the home and the shingles need replacement too. Per my Uncle who works in the construction trade option 2 is viable, but I wanted to ask the opinions of others too before taking on such a large task (plus he was drinking when we discussed it
) My plan would be to tie in additional 2x6's over the exsisting structure, insulating in between the 2x6's, install vapor barrier, then battens and finishing of with a steel roof. Do-able??
Any suggestions or ideas appreciated
J
