Frame Of Door Is Plumb And Level, Door Itself Is Not - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 11:11 PM   #16
Registered User
Rewards Points: 526
OK, guys, let's stop the bickering now. I will start cleaning this up, if needed.
I have moved bottom plates over (1/4-3/8") to line the walls on many occasions, especially with exterior double doors. You have to or the door may shut/open by itself because the bottom plate is not lined with the two tops and other bottom plate when "cross-stringing". It is necessary and does work as stated.
Kirk stated to plumb the jamb, read his first response- #5. #2 happens automatically when you do #1. #3 is if the RO is out of plumb more than doing step #1 and 2 will allow you to get the jamb plumb and staying in the wall thickness.
I have also recessed the drywall with a utility knife to install the casing and caulked behind the casing to fill the gap when the jamb is plumb but the wall is out of plumb at the top (floor materials stop you from moving bottom plate). I have set doors for over 37 years, none of these fixes are ridiculous. The plaster sometimes cracks, the drywall- never.
OP, a picture would help.......
Please add helpful comments as this is why we are here.
Thank you, Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
rock16 (10-31-2011), woodworkbykirk (11-01-2011)
Exterior Door Leak around Weatherstrip/Frame not Plumb woodardhsd Building & Construction 9 09-01-2011 05:17 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Kitchen Cabinet installation, upper cabinets not level BillyJack Kitchen & Bath Remodeling 0 06-30-2010 08:07 AM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 12:41 PM
