Frame Around Back Of Block Fireplace In Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 09:09 AM   #1
Rewards Points: 133
Frame around back of block fireplace in Garage
My garage is currently unfinished with the exception of the fire-rated drywall on the shared wall of the garage. Also on this wall is the back of the fireplace that projects into the garage. I was wondering what, if anything, I have to do to frame around the chimney. I would like to build two built in storage cabinets on each side, and a flip down work table across the back. It does not get warm on the back when we have a fire, and the chimney was inspected and cleaned at the beginning of last season.
Here is a picture I found online similar to what I have for reference:
jimmyfloyd is offline   Reply With Quote
Old 10-22-2013, 08:40 PM   #2
Concrete & Masonry
Rewards Points: 468
I can't speak for NY code, but HERE in WI, you would need to keep any combustable framing (wood) 2" away from the block in the scenario posted. I know it sounds like overkill, but when you enclose the backside of that chimney, it will trap heat inside.......
jomama45 is online now   Reply With Quote
Old 10-22-2013, 11:59 PM   #3
Rewards Points: 12,790
Same thing here.
Old 10-23-2013, 12:37 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
same in Massachusetts
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Garage door frame slumping. kadetklapp Building & Construction 24 03-19-2012 11:00 AM
Wooden Garage Door Frame Caulking alondis Building & Construction 2 08-12-2011 10:19 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
brick work for an old garage, steel frame needed vote4Pedro Building & Construction 3 02-12-2011 02:52 PM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 02:48 PM
