Fountains Of Water Pouring Through Basement Walls - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 04:54 PM   #16
Thanks for all the replies. I have decided to address the problem by building the roof which extends past the patio with a gutter and downspout to divert water away from the foundation.
Which leads me to my next question... Should I install concrete footings for the 4X posts, or can i get away with anchoring them to the slab?
Thanks again.
dlr1200 is offline   Reply With Quote
Old 11-09-2010, 08:15 PM   #17
Rewards Points: 4,534
i'd attach it to the slab if i were you because that will be less conc to remove when you decide to do this work properly,,, i expect this new roof will stop or divert the water temporarily however it won't be permanent,,, in the meantime the underground waterways will be leading other drainage water down alongside your foundation wall & infiltrating the blocks,,, that wtr will be contaminated w/soil acids ( acid rain, deleterious mtls ) which will & are attacking the lime in the cement which was used to form the blocks,,, in the end, the blocks will rot & collapse.
divorces are so expensive because they're worth it there's also a good reason concrete foundations cost more - they're WORTH IT, TOO ! ! !
in theory, there's no difference between theory & practice,,, in practice, there is,,, some of the responders to this post are theorists !
Tags
french drain , surface water , waterproofing , wet basement
Water seeping though bottom of basement stairs Sforza General DIY Discussions 18 03-11-2011 02:42 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
basement walls chuckofaltrades Painting 1 10-27-2009 10:51 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
