Foundation Wall Spalding: Old Or New Spalding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 10:27 AM   #1
Foundation Wall Spalding: Old or New Parging?
I have spalding of sandstone walls in my basement and was wondering how to identify if the parging is old lime based or was portland cement added later.
The basement was painted so I'm thinking the spalding was caused by moisture trapped by the paint. My wife thinks the parging is lime mortar because it crumbles and looks like very rough agregrate sand was used.
If the old parging is lime based I plan on repairing with lime mortar. If the parging is cement than it will have to removed.
Anyone out there have an answer?
Fishdaddy is offline   Reply With Quote
Old 08-26-2010, 01:45 PM   #2
Rewards Points: 4,442
its ' spalling ' & the cause is usually moisture penetrating the sandstone - even if granite had been used for walls, water/water vapor would still have penetrated,,, there wouldn't have been any significant spalling as the granite is strong enough to resist the damaging effects.
my suggestion's to remove the coating & let the walls breathe but we only do this work for a living
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 06:07 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
