Foundation Wall.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 09:10 PM   #1
foundation wall..
Hello, I'm thinking of adding a room to my home. The home has a conventional brick foundation wall. The addition will be 8x8x16 block. Will changing material hurt the value much? I plan to dress it up with Azaleas or something similar to hide the change of material. Also, what means are required to tie into the existing footing, and foundation wall? I'm in SC if that matters....
Boyce
rampeyboy is offline   Reply With Quote
Old 12-25-2008, 10:59 PM   #2
Rewards Points: 5,336
You would need to conform to the Building guidelines in the area you live. The specifications would be spelled out in the plans you file with the building dept.
This is not a project you just, "wing".
Ron
Old 12-25-2008, 11:24 PM   #3
Registered User
Termite's Avatar
The answers to your question depend greatly on soil conditions, imposed loads, and local code requirements and building practices.
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 01:49 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
