Foundation Tie Holes - How To Fill? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 10:46 PM   #1
Question
Foundation Tie Holes - How to fill?
Hi,
I have a bunch of tie holes in my concrete foundation. They were originally covered by hydraulic cement, but the builder did such a horrible job that they are mostly incomplete, cracked or outright popped out. There is a bunch of them and, since working with hydraulic cement is not that easy, I was thinking in using polyurethane foam (e.g. Great Stuff) to fill them in. The concrete is dry as a bone and I had never had water issues. I was planning to paint over it with Blue Seal (which I have to do anyways). Is polyurethane a bad idea?
globus999 is offline   Reply With Quote
Old 06-27-2010, 08:03 AM   #2
Rewards Points: 4,534
if exterior, roofing cement,,, interior the same,,, IXNAY on the foam - most pro's use hydraulic 'cause its fast.
Old 06-27-2010, 08:33 AM   #3
newer than a newbie...
Rewards Points: 83
similar question...
Hi there.
I have possible similar issues with my porch. It's concrete has separated from the doorway area. There was some kind of sealant used at one point, but that is cracking. The previous owner did a sloppy job of applying some silicone to cover things up but things are totally cracking now.
Could I not use the expanding foam in the big separation between the concrete porch and then apply a silicone or water based caulking to cover things up to make it nice and clean?
mcvane is offline   Reply With Quote
Old 06-27-2010, 08:45 AM   #4
notwithstanding you may have some structural support issues that should be addressed, foam or vermiculite can be employed to support the sealant,,, for best results, tho, use foam backer rod,,, remove all the old stuff, CLEAN the sidewalls, install the rod, & seal,,, ' tool ' the sealant to force it against the sidewalls,,, caulk is not a joint sealant.
Old 06-27-2010, 04:07 PM   #5
Hi, tx for the answer. Yes, I am aware that the pros use hydraulic, but all of they do a lousy job. they do not fill the holes all the way, which, in my case, average about 6 inches. To fill a 6 inch x 1/2 diameter hole with hydraulic is pretty much mission impossible. Sure, I can slap it on top, but it will penetrate about 1/2 inch tops. That's why I was thinking foam would be far faster. Stick the tube in, press as remove the tube, presto! Sealed. 30's tops per hole. In addition, the foam will stick to the inner walls and will provide an effective water seal (not my case but one never knows). On the other hand 1/2 inch of hydraulic won't provide anything other than a bit of esthetics's. Since the foam won't be exposed to oxygen or UV (from the sun) it won't decompose. Is there any reason why I should not use foam? tx! in advance.
Old 06-27-2010, 04:50 PM   #6
you got a jobonie now its easier to understand,,, i'd have no problem w/your method if you finish w/mortar/hydraulic,,, dampen the conc 1st - never patch a dry surface
Old 06-27-2010, 06:25 PM   #7
Registered User
Rewards Points: 5,216
"Is there any reason why I should not use foam? " ------ because it is an effective air barrier. Only if it is applied 8" thick is it a water/vapor barrier. http://www.henry.com/fileadmin/pdf/H...l_Brochure.pdf
http://www.buildingscience.com/docum...gs?full_view=1
Be safe, Gary
Old 06-27-2010, 10:05 PM   #8
Be safe, Gary
Hi Gary, not to sound pedantic, but on the first document, in page 6 it indicates that Open Cell SPF @ 3.5 inches has the same permability as housewrap, which is very good. In my case that would be 6 inches. Therefore, it should work OK. Lastly, I am planning to coat the entire wall with an elastomeric gas-barrier. So, the more the merrier. Or... did I miss something?
Old 06-27-2010, 10:08 PM   #9
Tx. Out of curiosity, why do think that hydraulic absolutely must be the last layer? Can't I just leave it w/the foam? I am planning to coat the entire wall with an elastomeric, gas-resistant layer. That will take care of gases + water. There are no structural issues either, that I can see. I checked the code of the area where I live in, and couldn't find anything (then again, I am surely missing something). Tx! again.
Old 06-28-2010, 12:04 AM   #10
Registered User
A vapor barrier is a lot different than a vapor retarder in that it stops all moisture. Foam is a vapor retarder at 1.1 per inch/ 2 = .55 /2 (4" -- 1/2 again) = .275/2 again (6") = 0.1375/2 (8") = .06875 because it is below .1 now it is a vapor barrier or a Class I vapor retarder. As was in the middle of the BSC article. http://www.energysavers.gov/your_hom.../mytopic=11810
Tyvek has a perm of 67, Typar- 16 (my numbers may be slightly off) a big difference between just those: http://www.typar.com/pdfs/Typar_vs_Tyvek.pdf
http://www.panhandleinsulation.com/b...materials.html
http://www.dyplastproducts.com/water..._permeance.htm
Be safe, Gary
Old 06-28-2010, 11:14 AM   #11
[snip]
Be safe, Gary
Got it! TX!
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 12:17 PM
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 11:31 AM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 09:16 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
What Can I Use to Permanently Fill Holes in Sump Pump "Poly" Tubing? kmcrawford111 Plumbing 12 06-27-2008 08:24 AM
