Foundation Skim Coat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 12:29 PM   #1
kwikfishron's Avatar
Rewards Points: 348
What would be the best way to get this mess looking like new again.
There is 5-6 spots like this large building probably built in the 50ís.
Besides peeling all the loose stuff off , what kind of prep and mix?
kwikfishron is online now   Reply With Quote
Old 07-26-2010, 01:15 PM   #2
Rewards Points: 582
It may be worth taking the scratch coat off as well as it doesn't look scratched. Use 1/1/4 lime/cement/sand for the scratch coat and scratch it out horizontally.
1/1/5 for the top coat. Use washed plastering sand rather than building sand.
stuart45 is offline   Reply With Quote
Old 07-26-2010, 04:22 PM   #3
Rewards Points: 348
Couldn’t I just grind some scratch into the coat?
Old 07-26-2010, 05:53 PM   #4
Rewards Points: 582
Originally Posted by kwikfishron View Post
Couldnít I just grind some scratch into the coat?
It would help, but the scratch coat needs to be in good condition itself and not blown from the brickwork or flaky, sandy etc.
This type of stuff can help adhesion.
http://www.permagard.co.uk/index.php...products_id=77
Old 07-26-2010, 06:37 PM   #5
Rewards Points: 348
Sorry, I haven’t busted into it yet. I am assuming (hoping) that the scratch coat is tight.
If it starts falling off with the rest of it I wouldn’t even think about grinding grooves. Then again if it’s a rock, why mess with it?
Thanks for the link.
Skim Coat Tools? Knives, Trowel, or Magic Trowel?? Lovegasoline Building & Construction 7 08-01-2012 10:25 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 10:59 AM
Skim Coat bigfixer Painting 8 02-23-2010 11:42 PM
Skim coat peeling in bathroom. ? 2031pratt Painting 17 03-05-2009 02:33 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
