Foundation Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 03:22 PM   #1
bml.4517's Avatar
Check out the picture on this old house. There is a 12 foot section of wood rot above the block foundation that the house lays on...not sure the technical name. Any thoughts or pro opinions on how to go about fixing the issue?
bml.4517 is offline   Reply With Quote
Old 09-24-2012, 03:35 PM   #2
id call a pro on this one bud, i wouldnt touch that with a ten foot pole
firsttimeremode is offline   Reply With Quote
Old 09-24-2012, 03:42 PM   #3
bml.4517's Avatar
Well my old man is a carpenter, has some good experience under his belt...so in the end he will hook me up with some much needed help. I enjoy learning from people that are so much more experienced than myself. Thanks for the reply buddy
Old 09-24-2012, 06:01 PM   #4
Civil Engineer
Rewards Points: 4,700
That is a pretty common problem, deterioration of the sill beam likely due to water infiltration. Can't tell from the photo if this is a problem affecting one foot of sill, or the entire house. The options for resolving the problem depend greatly on whether you need to fix a small area, or you plan to replace the entire sill (i.e. is this photo typical deterioration around the whole house, or is this the only bad place?) Let us know, then we can discuss options more effectively.
Old 09-24-2012, 06:20 PM   #5
Rewards Points: 13,458
It's called a rim joist.
Any chance there's a deck porch or stoop againt the side of the house in that area on the outside?
It needs to be fixed from the outside.
Post a picture of the outside wall in that area.
JetSwet (09-24-2012)
Old 09-24-2012, 06:33 PM   #6
bml.4517's Avatar
There is about a 12ft long section of deterioration. Its on the front of the house which on the other side of the wall is dirt. There is a 25yrd concrete porch above the dirt on the side where the rot is.
Old 09-24-2012, 06:35 PM   #7
bml.4517's Avatar
There is a concrete porch on the outside above the wall unfortunately...always something haha. I will post more pictures in the morning. Thanks joe
Old 09-24-2012, 06:46 PM   #8
Happens everytime someone builds it that way.
Old 09-24-2012, 06:56 PM   #9
bml.4517's Avatar
Here is the outside view
Old 09-24-2012, 08:32 PM   #10
If that was my house, I would first re-connect that gutter downspout so that you can channel rain away from the foundation.
I would then find the rot location from the outside and peel off few siding layers to determine your situation.
But based on your first picture, you may have to replace that sill, along with part of the rim band.
allthumbsdiy is offline   Reply With Quote
Old 09-24-2012, 09:33 PM   #11
bml.4517's Avatar
Good eye, thumbs! Thats actually on the morning schedule for the house and thank you. The renters I had in there earlier this year have been very destructive and have just made a complete mess but back to the point. That concrete is gonna be a pain to take up but it will have to be done. Thanks ole buddy
Old 09-24-2012, 09:46 PM   #12
The other option would be to lift the whole house, your choise.
I've seen that exact same thing done to houses dozen of times, by both DIY's and the pros.
What in the would do they thinks going to happen to the side of the house when you bury it like that, it's got to rot.
It also give the termites a direct route into the house and never be seen.
Once you get that concrete out come back. There's a fix so it will not happen again.
Old 09-25-2012, 05:27 PM   #13
When I had to remove my concrete patio (very small compared to yours), I rented Hilti DSH700 concrete saw and Makita HM214c electric demo hammer.
If you want to see some pictures, google "how to replace a rotted rim joist and sill plates part 3"
Best,
Old 02-09-2014, 08:37 AM   #14
I agree, fix the drainage first, then fix the woodrot if its limited to a certain area. check if there are any other parts exposed to the earth outside and do some waterproofing to make sure the same thing doesnt happen again.
SinaiConstruct is offline   Reply With Quote
Next Project? Foundation Repair Warpath Building & Construction 2 07-22-2012 07:10 AM
Rotted wood & Fieldstone foundation repair Glenmc Building & Construction 7 06-01-2012 07:49 AM
holes found in foundation repair belle18 Building & Construction 6 11-16-2011 12:08 PM
Pls help! DIY foundation crack repair question tspaulin General DIY Discussions 3 07-16-2009 07:39 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
