Foundation Question - Bored Hole In Foundation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 09:31 AM   #1
Foundation question - Bored hole in Foundation?
I am in the process of building a new home and upon my last visit to the construction site I notices they had drilled a hole in the foundation next to some plumbing . When i asked one of the workers, he replied that they had to move a drainage pipe over. I didnt see if they covered the opening because they placed the cabinets and counter over it. will this affect the foundation or anything else?
vxg6997 is offline   Reply With Quote
Old 01-29-2010, 09:39 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
Wrong forum.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-29-2010, 10:51 AM   #3
Rewards Points: 1,016
Originally Posted by rusty baker View Post
Wrong forum.
Why is that - please elaborate?
Old 01-29-2010, 11:06 AM   #4
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
It's ok and normal to put some holes in a slab, so long as you don't go overboard.
I had my slab foundation leveled last summer. They did a total of 34 piers, 21 around the outside and 13 on the inside. For the inside piers they had to jackhammer through the slab, so I had 13 holes intentionally put in the slab. They covered all their holes up pretty nicely. House is level now.
brons2 is offline   Reply With Quote
Old 01-29-2010, 11:14 AM   #5
wow..thank you.
Old 01-29-2010, 11:48 AM   #6
Foundation or slab? Its typical to bore through the foundation if they didnt put a sleeve for the plumbing. It is perfectly fine as long as they filled any old holes and sealed all around the pipe to create a water tight seal.
wnabcptrNH is offline   Reply With Quote
Old 01-29-2010, 01:42 PM   #7
thank you
foundation question for building a small cabin TNeat Building & Construction 3 08-01-2007 06:08 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
Foundation question jerome8283 Building & Construction 3 01-18-2007 03:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
Foundation movement question kelly001 Building & Construction 5 10-02-2006 06:09 AM
