Foundation Problems - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 02:29 PM   #1
Foundation Problems
I am not looking for do it yourself advice rather general information. I have a foundation where about 1/2 is wood laid on the ground and the rest is either cinder block or concrete. I am looking for cost effective solutions to replacing the part of the foundation that is wood on grade.
That part looks like two 6" x 4"'s laying one on top of eachother. The bottom one is in contact with the ground and is partially rotted underneath and the top one I believe acts as the sill plate and is in good shape.
Any "helpful" ideas are welcome.
Gandalf is offline   Reply With Quote
Old 07-18-2010, 07:32 PM   #2
Rewards Points: 5,336
Post some pictures. The 6" x4" thing is also confusing.
Ron
Old 07-18-2010, 09:04 PM   #3
Civil Engineer
Rewards Points: 4,522
Concrete block is generally less costly than concrete as a foundation material. May also be easier for a DIYer to install than concrete. Wooden foundations are used sometimes, but there are always issues with rot, I don't care what kind of wood you use, to my mind wooden foundations are trouble. In New England, fieldstone foundations were common, if you have fieldstone available, are a competent mason, and there are no code issues, you can build a very low cost foundation with fieldstone, however it takes skill and time.
Down south pier and beam foundations are often used. This is a very low cost solution, however the house is typically not attached to the pier very well, and can float away or blow away in a severe storm. Pier and beam is typically not a code approved technique, however if you are not governed by code, and are looking for the absolute cheapest option, that's it.
Old 07-19-2010, 04:49 AM   #4
Rewards Points: 4,454
dan, does anyone still sell cinder block ? in ny, nj, ct, & pa, once the wtr started infiltrating thru those walls, it wouldn't take long for the soil acids to eat the cement's lime & cause the rot,,, good $$$ replacing collapsed foundations we're build several in augusta w/conc block piers/ p/t wood beams for crawl spaces - never liked 'em but those were the specs never thought the engineered wood fnd walls were worth a da'n, either
support the house & rip out the wood, replace w/conc footer per local code & frost conditions, then conc block - not as good as complete concrete but, if built correctly and waterproofed right, its the best bang for the $$$
Old 07-19-2010, 04:05 PM   #5
http://img.photobucket.com/albums/v43/phageist/000_3542.jpg
The bottom of photo shows wood on ground, on top of that is sill plate, on top of that is floor joist and at the very top of the photo you can see a little of the tounge and grove flooring. the beam on the ground is rotting a little on the underside.
Foundation Problems shonekat Building & Construction 3 09-01-2009 06:17 PM
Foundation Problems Rosezeee Building & Construction 5 02-10-2009 10:06 AM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
Foundation Problems LeahWood Building & Construction 13 08-01-2007 02:12 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
